I have bought 2 Godfather 2 games for my PS3 and neither has worked. They first disk I did not test, I just returned it; however, the 2nd disk i did test on another PS3 system and the disk worked fine. The disk loads to the frist screen but then I can't go any further than that to start the game. It is like it locks up at the title screen. HELP!
Try to RESTORE FILE SYSTEM on your ps3.
Follow this guide,
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Testimonial: "Eric your a genius! Your instructions worked! Thanks!!!"
hey
there smilly47
Sounds
like the Freeze up error,please see the Freeze up section Below
When
your Experiencing Problems with the PS3 like this you mainly have 2
options to take, I will go through each one now so you know what to
do.
Option
Send
The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will
send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will
be $150
Waiting Time:
4-6 weeks
Option
The PS3 Repair guide
When your suffering problems with the PS3 its
often easy enough to fix it at home with a good ps3
repair guide. There famous for fixing major problems like:
The
YLOD - Yellow light of death/ Red light error
The
Hard disk Corruption error
The
Red Screen of death - Serious error
PS3
No Signal Error - no display
But not everyone knows they can fix simple
settings problems like all error messages and the no display error,
av and hdmi screen problems and more.
Price: averages between $30 - $40
Wait time: instant download and repair within 2
hours
I really hope I have enlightened you and you do
what is needed to fix your problems with the PS3 and get back to
gaming soon as possible
Please leave any comments if you need any
further assistance
Best Regards
PS3 Fixer
