Kicker 06ZX750.1 Car Audio Amplifier Logo
Question about Kicker 06ZX750.1 Car Audio Amplifier
My kicker mono amp doesnt show positive or negative i need to know
Posted by m_martinez2 on
electronic & computer repair& servicre
  • 12,061 Answers
99 times out of 100 the Case is NEGATIVE therefore the "Other" connection MUST be Positive. Thats the answer.
Posted on Jan 27, 2010
One dual 15 with a class d one channel amp. mtx comp sub with kicker zx1000.1. how do u wire voice coil so amp doesnt get so hot.
Positive out from amp to positive on first coil. Negative on first coil to positive on second coil. Negative on second coil to negative out on amp.
If you have 4 ohm coils, that will make it an 8 ohm load for the amp. It won't be anywhere near as loud, but it'll run a lot cooler.
How would u wire a single 10 inch sub 2 olm kicker l5 to ur amp
First you have to determine if your amp can run a 2 ohm load. If it can, (check the manufacturers documentation on the specs for the amp) then just wire the positive to the positive on the amp, and the negative to the negative on the amp. This assumes that the amp is a mono or one channel amp. If it is a two channel amp, you may be able to bridge it, if the amp can run that way. (Positive of one channel to the positive on the sub, then the negative of the second channel to the negative on the sub. MAKE SURE THE AMP CAN DO THIS BEFORE WIRING IT THIS WAY!!
This could blow the channel (cause damage to the amp) if it is not supported.
If you list model and manufacturer of amp, I can assist with more certainty.
Bruce
ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2
For a 1ohm load it's positive to positive and negative to negative run 1 wire from one speaker to the other. Positive to positive neg to neg. Then 1 wire from the speakers to the amp. The amp will have + - + - on it's inputs for left and right speakers (if stereo) Use the outside positive and outside negative. If there are any switches on the amp that say "mono" "stereo" switch to "mono". Hope this helps
How do you hookup 2cvr 12 to a mono amp?
Hook together both positives from each speaker together and both negatives from each speaker together and hook them up as one connection to your amp.
1helpful
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
1helpful
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
I have 2 kicker 07CVR124 12" dual voice coil with a 800 watt mono pioneer amp. How do I wire it correctly
I'm not sure what pinoeer amp you have. If I remember correctly some are 1 ohm stable. In this case you would be able to wire everything in parallel. Meaning, with the voice coil, wire the positive to positive, and the negative to negative. Then wire the subs together positive to positive, and negative to negative. This will give you the total impedence of 1 ohm. If it isn't 1 ohm stable the best you could do is 4 ohms. To do this you would need to wire the voice coils in series and the subs in parallel. Meaning, wire the negative to positive and the positive to negative. Then take the subs and connect the positive to positive and the negative to negative. I hope this isn't too confusing. If you need further assistance let me know. Good luck
-Andrew Hawkins
4answers
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Need help bridging
First check your gain it may be turned down. I personally dont bridge speakers. I put each speaker to its own channel on the amp.Make sure positive to positive and negative to negative. Try hookin up two speakers to the amp (not bridged) and turn your gain up around half way. Make sure you amp is switch to lowpass not high since most amps have crossovers built in now. The more speakers you have the less output from each speaker from one amp youll get.
Wiring woofers
Well, you have the 4 ohm dvc kickers, and your amp being stable to 2 ohms doesn't go together very well. If you wire the voice coils in series, and hook the speakers to the amp in parallel, you get 4 ohms, which doesn't use all the power your amp is capable of. If you run the voice coils and the speakers in parallel, you'll drop the resistance to 1 ohm, and probably fry the amp, or at least deal with overheating issues. Better be safe than sorry. You need to run each speaker in series, which means running a positive and negative to each speaker, and a jumper from those terminals to the opposite colored terminals on the second voice coil. Diagram can be seen here: http://www.kicker.com/06/tech-support/manuals/manuals/02SoloBaricL7manual.pdf That puts two 4ohm voice coils in series, and raises the resistance of each speaker to 8 ohms. Then, you have to run both speakers in parallel to the amp. When you run two 8 ohm circuits in parallel, the total resistance of the circuit is 4 ohms. That means seperate positive and negative wires to each speaker. If it is a mono amp, connect both negatives to the negative output, both positives to the positive output. If it is a multi-channel bridgeable amp, You'll probably connect the negatives to one side output (right for example) then connect the positives to the opposite side output (left for example). If you need to bridge your amp, make sure it is bridgeable, and also that you have the speakers bridged to the proper amp outputs. If not sure, reply back here with the amp model number, and maybe I can help you further.Thanks, and I hope this solves your problem.
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
