There may be dust or dirt on the small glass strip. Lift the scanner unit so you can see the scanner glass. To the left you will see a small glass strip. That is the area that you will need to clean. Make sure it is spotless as any stuck on dirt will cause the problem you are having.
This article provides the self-diagnostic
steps necessary to evaluate top-to-bottom streaks that appear when
copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
Think of it this way:
Suggested Diagnosis and Fix
Step
Action
Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
Perform a visual inspection for any of the following recurring culprits:
Other Possibilities
If...
Then...
Vertical lines appear only when printing...
Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical lines appear when you lay the page on the flatbed...
Vertical lines appear on ADF-fed printed copies, but
they do not appear on scan-to-network [e-mail, FTP, folder (PC),
solutions]...
The glass is clean with no dust. I inspected the place where the line would be if it was caused by dust or a mark on the glass and it is crystal clear.
