Question about Texas Instruments TI-84 Plus Calculator
I changed the batteries in my ti-84 and it will not turn on.
Posted by skcharland on
Anonymous
    New Friend:
Double check that all the batteries are new, and that they are all completely in and in correctly. Also, it may be an issue of screen contrast. Hit the "2nd" button and then press and hold the up arrow. If you don't see anything, press "On" and try the same process again.
Posted on Jan 27, 2010
Ti 84 water damage
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Nov 11, 2013 | Texas Instruments TI-84 Plus Calculator
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
TI 84 plus silver edition wont turn on
Sep 23, 2012 | Texas Instruments TI-84 Plus Silver...
I can't turn my ti-84 plus on.
Aug 21, 2012 | Texas Instruments TI-84 Plus Calculator
My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
May 15, 2010 | Texas Instruments TI-84 Plus Silver...
When i turn on my ti-84 the screen is black - i have changed the batteries
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key until the screen lightens. If you go too far, press and release 2ND, then press and hold up-arrow.
May 10, 2010 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
Calculator ti-84 doesn't turn on
I would suggest that you make sure all batteries are making contact if not that check your off on switch
Mar 06, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
