Question about Hurricane Health & Beauty
Wiring has been disconnected need to rewire pride hurricane pmv scoote. Need service manual or wiring diagram.
Posted by Domingojr on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Hello, If you need any manuals or wiring diagrams go to;
http://www.pridemobility.co.uk/ipb/
Username : pride
Password : access
Hope this helps...
Posted on Jan 27, 2010
Where can i get brushes for pride hurricane in uk
I would contact pride or a service centre as if you put the wrong grade of brush in the motor you can damage the comm and motor.
The motors are not cheap.
Mar 03, 2015 | Pride Mobility Products Hurricane PMV...
Pride mobility scooter wiring diamgram
Go to Pride's web site to download the service manual.
Jul 28, 2014 | Pride Health & Beauty
Pride destiny error codes
Pride's website has a service manual for download. It will define the error codes and tell you how to fix it.
Feb 06, 2014 | Pride Hurricane 4 Wheel Personal Mobility...
Horn will not sound pride hurricane
The horn is a a small peizeo horn. You can generally get them at radio shack. The horn voltage is 24v. Before you run and get a horn, you need to see if the horn accidentally was disconnected due to a bad solder joint or the wire had been accidentally pinched and cut from a previous service. This horn generally does not go bad. The button on the dash is usually the culprit. While you have it apart you need to look at the button closely. The best way to check this this to have the scooter on and touch both wires in the bottom of the switch with a screwdriver and see if the horn sounds. If it does, replace the switch. If it doesn't, then it is either the horn or a bad circuit. Depending on how comfortable you are messing with electricity. You can apply direct voltage from the batteries with a jumper wire and see if the horn works or you can use a voltmeter to check the circuit. I usually just use the jumper wires. It's fast and easy. If horn works then it's in the circuit, if it doesn't you have to start with replacing the horn.
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
I have to replace the rubber boot on the tiller is there a repair manual for that
You can call Pride Mobility 1-800-800-8586 They should be able to help you.
Good Luck
Tim
May 02, 2011 | Pride Hurricane 4 Wheel Personal Mobility...
I have a Pride Mobility Hurricane PMV, None of the left side signals, or parking lights work. I think I have it down to the console board. I have 12 volts going in but nothing when I activate the left...
Hoping your problem is in the wiring to and from , or the light itself , usualy when the board goes , nothing works... make sure you test every contact point for juice to and from , before you discard the possibility...!!!!
Jan 05, 2018 | Pride Mobility Products Hurricane PMV...
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Health & Beauty Logo
1,785 people viewed this question
Top Hurricane Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Hurricane Health and Beauty Expert? Answer questions, earn points and help others
