1.First, connect the power adapter to the receptor at the back panel of the router. Plug the adapter to the wall socket.
2.Power off your Cable or DSL modem
3.Connect an Ethernet cable to the Ethernet jack located on the Cable / DSL modem.
this will take several steps but there isn't enough space here to give all steps. I will give steps in 2 and 3 parts
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
Please let us know the complete issue. What is the Operating System and is this the first time you are trying to connect... Provide complete information to assist you accordingly. Also provide Brand of your Laptop
