Question about Anthology Solutions Yellow Machine P400T (250006001) 400 GB Network Hard Drive
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Posted by jfelger on
  • am0251 Apr 25, 2010
    HELP !! I have this yellow machine , but I lost the driver disc , Can anyone tell me were can I download it back ? Please.............!!!
Data365
    New Friend:
  • 196 Answers
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Posted on Feb 17, 2010
I need a static ip address how do i get one
Static IP address should come from them, some of our service providers give paid static P addresses to customer, you can check it from them for they are the one who have control providing ip address either static or dynamic.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I want to use my linksys nr041 as an extended network hub how do I do this
set it up as a static IP also set the gateway to the ip of the other router. example:
Router #1: IP address: 192.168.0.1
Router #2 IP address Static 192.168.0.2 / Gateway:192.168.0.1
Oct 25, 2009 | Linksys (NR041) Router
Cant access my router ip number
go to start then click run adn type cmd then press enter, on the command prompt type ipconfig/all then press enter then look for gateway IP address, that will be your router's address unless you have a static IP set up on your machine.
Sep 14, 2009 | Linksys Wireless-G WRT54G Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys BEFSR11 Router
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Anthology Solutions Yellow Machine  P400T (250006001) 400 GB Network Hard Drive Logo
817 people viewed this question
Top Anthology Solutions Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
