Question about Dell PowerEdge 2500 Server
Problems installing windows server 2000
Im having problems installing win server 2000 on my two dell poweredge 2500's.
the install will be fine untill it starts to install the devies it will freeze at about 30%
  • Anonymous Jan 27, 2010
    thanks info2u
    the hardware is compatible with server 2000
    and i belive that the drivers should all ready be installed beacause i used the Server Assistant CD before windows install.
    even tho i have used the cd do i still need to use the f3 key
    yes im doing a fresh install,the servers used to have 2000 server on them before but had to replace hard drives. they also arn't connected to a network.
Nouveau IT, LLC
  • 596 Answers
Make sure the hardware is compatiable with Server 2000. Most of the time you will run into a stale if hardware is not compatiable or windows does not have a compatiable driver for those devieces. If you have the drivers for your hardware, install those at the begining of the server install. (You will see at the bottom of the screen press F3 to install 3rd party drives. After the drivers are installed, you should be able to proced.
Good Luck,
C2Solutions
Posted on Jan 27, 2010
  • Nouveau IT, LLC
    Nouveau IT, LLC Jan 27, 2010
    No, you should not have to use f3 if everything is good with the HAL (compatibilty) My next suggestion would be make sure you are not connected to a network while performing the install and try again but let the system run for a while to make sure it is not just formatting the hard drives. If I may ask, are you performing a freash install? Did these server have an os before? Are these two server getting the os installed at the same time over a network connection?
    It's been a while since I worked with Server 2000 (nothing wrong with it, just been a while.) I will continue to go through some of my old notes to try to resolve your issue.
    C2Solutions
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
I have a dell poer edge 6850 server. it shows scsi disk not found. i want to install windows server 2000. what should i do for that?
To install Windows server 2000 on that machine you will need Dell PowerEdge™ Installation and Server Management CD you can download ISO file from this link:
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Dell+PowerEdge+Installation+and+Server+Management+CD&cat=sup&x=6&y=5
P.S.
Burn that ISO file to CD, start installation from that CD and follow instructions it is quite simple.
Jan 21, 2011 | Dell PowerEdge 6850 (PE6850BB) Server
What operating system can be installed on Dell PowerEdge 600SC Server
depending on the amount of memory and processor speed i have installed windows 2000, windows XP. Linux, windows 200 server and windows 2003 server. it all depends on hardware requirements.
Jan 05, 2011 | Dell PowerEdge 600SC (Refurbished)...
My Dell PowerEdge 840 will not allow me to install Windows 2000 Server software. Evidently, the 840's graphics card does not contain the drivers for Windows 2000 Server. Is there a solution?
I am not sure where you got your information but I just checked Dell's website and they have Windows 2000 drivers for your server which include the video driver.
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PWE_P4_840&hidos=WNET&hidlang=en&TabIndex=)
If you are still having a problem then you should call Dell support. Every Dell server has lifetime free phone support.
If this helps please vote for my solution.
Sep 29, 2009 | Dell PowerEdge 1600...
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Setup can not find any hard disk while installing win 2003
During setup you must specify any raid drivers that are required. Have the raid controller driver on floppy and insert when prompted.
Mar 31, 2009 | Dell POWEREDGE 1950 Server
Lost password for Dell Poweredge 2500 running windows 2000
If the BIOS password, some dell's have a jumper to reset that.
A piece of software ERD commander may enable you to reset a windows account password.
Feb 02, 2009 | Dell PowerEdge 2500 Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Poweredge 2300 Configuration Help Appriciated :)
I have a older poweredge 2300 i get the following message run program setup.
Mar 26, 2008 | Dell PowerEdge 2300 Server
Open Questions:
Dell PowerEdge 2500 Server Logo
270 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
