ASUS P4V8X-MX Motherboard Logo
Anonymous Posted on Jan 26, 2010
New sata harddisk not detected
Mainboard ASUS P4V8X-MX: new SATA-harddisk (Maxtor DiamondMax23) is not detected.
  • Anonymous Jan 27, 2010
    Thanks for your ideas and comments, but meanwhile I found the solution: The brand new hd didn't work because it was out of order right from the beginning, so it could not work at all!!! in the meantime my pc dealer replaced this item by a new on, and now it works perfectly. thanky for all your time, greetings from germany, Bernd
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jan 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
7040
Points
41
The mother boards from that time you had to install the RAID drivers to use SATA drives. The drive disc which came with the mother board should have the drive, but I would suggest going to ASUS's web site and download the latest drivers. Click the link below, Select which OS (Operating System) you are using, Next click the little + box next to "IDE" and the drivers needed will be listed.
http://www.asus.com/product.aspx?P_ID=xCBogxJhh6yWBQRi&content=download
Testimonial: "thnaks for your qick reaction, see my comments as the case has been solved in the meantime, please see my comments, thanks."
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
404
Points
Go to BIOS,turn off the default audio.IF inbuild audio chip does not work properly then generally we turn off the default audio from the BIOS.Add new Sound card to the PCI Slot and add the driver.
Shofi uddin
Baruipur
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
ASUS K8V-MX Motherboard recognizing 320 GB SATA harddisk. Why?
It could be that your BIOS needs updating for this motherboard. Take note of your BIOS version when your computing is booting. Try hitting the Pause key to freexe the screen, but if no luck go into BIOS and see if the BIOS version is listed. You typically get in BIOS by hitting the "Delete' key on your keyboard when the computer starts up and the first bunch of words appear in white characters (might be a light grey)
Go here:
http://usa.asus.com/product.aspx?P_ID=dJ2XP7zr8tzeYbLp&content=download
Latest BIOS (note its a beta version ie not formally released) is
K8V-MX Beta BIOS 0501
Latest beta BIOS.
1helpful
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
I need a diagram of the atx pwr connector for an ASUS P4V8X-MX
If you mean power to the devices themselves, the 4-pin connectors coming from the power supply plug in to the drives. The red wire is +5 volts, the yellow wire is +12 volts and the black wires are ground (earthing) connections. IDE hard drives and CD drives use the same connector. SATA drives may have that same connector as well, but most use a different style. SATA-ready power supplies will have 1 or more plugs available. Adapters to switch from the 4-pin IDE plug to SATA type are available for supplies that don't have the right connector.
If you are asking what power pins from the mainboard power supply connector are supplying power to specific controller parts on the mainboard, that kind of detailed information is not available. Mainboards manufacturers do not supply circuit diagrams or repair information. They simply replace any boards that fail while still covered by the warranty, and expect you wil just buy a new one if the warranty has expired.
Much information about ATX boards including the power supply cable pins is found here:
http://en.wikipedia.org/wiki/ATX
2answers
Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
1helpful
BIOS cannot detect SATA harddisk
Most motherboards have multiple plug-ins for Sata drives. Try another plug in. This will typically solve this type of issue.
Same problem, but not solved
Matias,
Please remove the jumper on the SATA drive. Boot to the bios & see if the SATA drive is listed. If it is you're good. If this is the first SATA you have tried in the Asus board & my suggestion also failed to show the SATA drive you are left with two options.
One the SATA drive is defective or the SATA motherboard controller is bad. You can call Asus tech M-F 8:00AM to 5:00PM EDT. At 1-812-282-2787, there is little wait time when calling Asus tech. Asus does not charge you for calling them.
Mike
HELP ABOUT K8C-X motherboard
Hi thun, Unplug the power cable from the PC.
Please reset the bios. This is shown in you're user manual on page 1-17. (If you no longer have you're user manual for the Asus K8V-MX MB you can download it from Asus by clicking on this link):
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
Remove the SATA data cable & clean both ends of the cable with a few drops of alcohol on to a cotton swab. Than clean both SATA ports on the motherboard using the same method.
Also clean the SATA power connectors in the same fashion. (Allow time for the alcohol to dry).
You can help it dry using some canned air.
Re-connect the SATA data cable & SATA power cable to the SATA drive. (Check all other connections within the PC for good connections before closing case). (SATA data & power connectors are easily knocked loose, so be careful).
Plug the power cord back into the PC & boot the PC. Enter you're bios. Check the main menu & make sure the bios has listed the SATA drive. Than go to Boot menu. Page 2-27, 2-28 in the manual. Make sure you see the SATA drive listed here. If you are sure the SATA drive was listed in the main menu than it must also be listed in the Boot menu.
If it is not listed in the Boot menu than there is a problem with you're bios. You're board is warranted for three years from manufactures date. Please call Asus tech at 1-812-282-2787.
M-F 9:00AM to 5:00PM EST. You will need the serial number printed on a white label located on the pink LPT port. You can see this only from within the PC. Asus will ask for that S/N to determine if you're board is still within warranty. If it is, make sure you get a case number & instruction before ending the call.
Good Luck!
Mike
3helpful
7answers
SATA problem
Your bios is corrupted & needs to be flashed.
You will need to download the bios flash utility & a bios file.
creat a floppy disk with these to files that you can download from here. Click the link below.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
If you are not comfortable with flashing your bios you can order one from Asus by calling 510-739-3777 CA. Please have your model Number ready & S/N located on a white sticker on the pink serial port.
Good Luck!
Mike
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
