Question about Microsoft Computers & Internet
I need my server to monitor the log in and log out of other users in the cpu's connected to the server
Posted by reind2nd on
Anonymous
    Scholar:
  • 60 Answers
If your server has Windows Server 2003, then you can audit user logons via the event viewer. The Security section keeps an audit trail of when users log on and log off.
Advanced information can be found here - http://www.windowsecurity.com/articles/Logon-Types.html
Posted on Jan 26, 2010
Dell poweredge t300 server e1410 cpu 1 error
The e1410 is an error that is reporting an interruption to the CPU processes. It isn't identifying an issue with the processor specifically, it is just saying its processes were interrupted. Normally when you see the E1410 you will see another error listed with it in the hardware log. Do you see any other errors in the log? Also, what is the BIOS and Drac versions at currently? I ask because the server being very out of date can cause issues like this as well.
Let me know what you see.
Aug 30, 2014 | Dell PowerEdge T300 Server
We have installed the printer in a PC that is on the network so that different users can log on and print from it. However there is one user that when she logs on she cannot print. she opens up the...
Hi Good day!! Your network seems to be very busy that's why the user can't connect to your server which your printer is installed. OK i will give you step to connect the user which cannot print.
Server
1. In your Server right click your "My Computer" and then click "Manage". you should be in computer management box.
2. Click "Shared folder" in the Computer management and then click "session" after opening it you should see the user which is connected to your PC. delete some users.
User
1. Click "Start" - Setting - Printer and faxes, double click your printer, i think your printer status was unable to connect? try refreshing it while the server is deleting some user which is not using the printer.
when refreshing, monitor the status of your printer when it says Ready your PC is now connected to the Server and now you can print.. Hope my solution helps you!!
REGARDS
JR
Oct 19, 2010 | Datacard Group SP35 Card Printer
My monitor will not come on, it only states going to sleep, what can i do
It's a connection issue. Check that monitor and cpu are properly connected. Also check for faulty cables.
Jun 04, 2010 | PC Mall Pixelworks Cluster System...
Windows 2003 Logon script
create a user folder on the server.
create each login folder "PC0001","pc0002", etc............
set the user rights by right click on the folder and select properties. (you need all users name. otherwise, one of more people will not have their file on the server.
now, you need all fo the users that will be using that particular PC login, in order to create the user profile. unless you have one generic login.
right click on "my document" on each of the local machine.
redirect the path under the general tab. to where you wan the files to go to.
that will place the file where you want them to be. like you say it is machine direct, not user direct. i you want user direct, in another words, you want the user files to go to the server regardless where the user is, then you need a Domain Controller and Active Directory setup.
Nov 20, 2008 | Microsoft Windows Server Standard 2003 for...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Problem in proxy settings
Log Out...Could not Connect...
Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
Oct 27, 2008 | Computers & Internet
No signal on monitor
I think you need to connect the cpu cable with the monitor to start it.
if still your computer turns on without issue, but your computer screen is showing a No Signal message, it could be due to problems in the CMOS, RAM, VGA card, or the cable that connects your CPU to your monitor.
If the cable is a problem. You can get a new one at
Computer Memory CPU SSD HDD Upgrades for Servers Laptops Desktops
Mar 29, 2017 | Computers & Internet
Remote Login Failure
This message means that the user account you are trying to use does not have rights to log on remotely. You need to go to the server, log on as an administrator at the console. Once logged in, add the user account you want to use to the local "Remote Desktop Users" group.
Jun 17, 2008 | Microsoft Windows XP Professional With...
Logging on to server
You need to go into administrative tools and look for group policy.
In the local computer policy
Computer Configuration
Windows Settings > security settings > Local policies > user rights assignment. In the right hand pane find the policy for "Allow log on locally" Set the user accounts for those users which are allowed to log on interactively on the server. Be careful you dont lock the administrator account out.
Use in conjunction with the "Deny logon locally policy" if you need to.
Hope this helps
Mar 22, 2008 | Microsoft Windows Server Standard 2003 for...
Solving Hp thin clients problems
You dont have one thin klient connected to a Server, as the Serversoftware itself max. the cost of ordenary poeple.
furthermore, a Server for that purpes is normaly with two CPU's and at least 4GB of RAM, - and that would set you back at least US$ 5 - 10.000.
My "help", therefor would bee "stay the hell away".
Feb 29, 2008 | HP Compaq Thin Client T5300 (dc643a#aba)...
Computers & Internet Logo
112 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
