Question about HP DeskJet F4280 All In One Printer InkJet
How to print cd covers with HP Photosmart Essential 3 5 i have microsoft office 2010 beta and open office 3.1 installed and some avery standard #8931-face-cd labels nd can not figure out where the tools are to use this template ( could do itolder microsoft office but can't find out how in 210 beta)
Posted by justchuck69 on
NOEL
    Top Expert:
  • HP Master
  • 8,546 Answers
Hi Justchuck69.
You can use the software that came with your HP Photosmart all-in-one printer to create CD covers and then print them on the discs. For this to work, the CD must be printable, and you shouldn't use CDs that have their manufacturer, size and speed already printed on them. You must use the latest HP software to create and print the covers. If you can't find the installation disc that came with your printer, download the latest version of the software from HP's Support website.
1 Launch the HP Solution Center that was installed on your computer when you installed the HPsoftware.
2 Click the "View Library" button to open the photo library and then select the folder that contains the images you want to use for your CD cover from the left pane. Click the "Add This Folder" to add the folder to the library. You can only use photos from the library to create the CD cover.
3 Click the "Back" arrow near the top of the window to return to the Welcome screen.
4 Click the "Create" button, choose "Disc Labels," and then click either "Standard CD" if you want to print on a standard CD or "Mini CD" if you want to print on a mini CD. Click "Choose This Format."
5 Choose a design from the list of designs, and then click the "Choose This Design" button.
6 Select the photo or photos you want to print on your CD, and then click the "Add These Photos" button.
7 Use the controls in the Edit Your Disc Label section to zoom, rotate and reposition the photo. Click the text boxes and type or paste some text, if you want to add text to the label. Click "Create" when you're satisfied with the result.
8 Select the HP Photosmart printer from the "Printer" drop-down box, and then ensure the "Standard Sizes" option is selected.
9 Click the "Print" button when you're ready to print the cover on the CD. The "Open CD/DVD Tray" message is displayed on the printer's LCD.
10 Pull the CD/DVD tab below the main tray to remove the CD holder, and then place the disc on the ring of the CD holder with its print-side up. Gently press on the CD until it snaps into place.
11 Lower the CD/DVD tray located just below the control panel, and then insert the CD holder into the tray. The printer starts printing as soon as the white lines on the tray and holder match up.
12 Wait until the printing process is complete, remove the CD holder from the tray, let the ink on the CD dry for a few minutes, and then remove the disc from the holder.
13 Close the CD/DVD tray, and then insert the CD holder back into the storage space.
Tips
  • checkPhoto Creations, the latest software from HP, does not support printing CD labels. HP Photosmart Essential is available for download from HP's FTP website (link in Resources).
  • checkThe back of the HP all-in-one printer must be at least three inches away from the wall or other objects.
  • checkIf you use a small CD, don't forget to flip the holder ring over the disc before you snap the CD holder into place.
  • checkYou can add additional folders to HP Photosmart Essential if you can't find the photos you want to print on the CD.
  • checkYou can bold or italicize the text when you type it, but you can't choose a different font or change the size of the text.
  • checkAlternatively, you can use a free third-party utility to create the CD cover and then print it on the disc.
Warnings
  • closeDon't turn off or unplug the printer from the computer while it prints the CD cover.
  • closeInformation in this article applies to HP Photosmart Essential 3.5. Procedures may vary slightly or significantly with other versions or products.
Ads
CD/DVD Label Software
Download free software to create CD and DVD labels on Windows or a Mac
NCH Software
Start Download
Microsoft™ 64/32 Bit Driver Download Driver Support™ Free Scan
Driver Support.
plus you could read up some more at this link if the above does not work for you.
How to print cd covers with HP Photosmart Essential 3 5 Google Search
Posted on Dec 15, 2017
5 Related Answers
Ekse
  • 13434 Answers
SOURCE: HP Photosmart C4180 won't print
hello
you can get the newest vista software for your laptop from
CLICK HERE
Posted on Apr 28, 2008
nelgt
SOURCE: cd label
I finally figured it out. The default DISC LABEL got set to HP TATTO. It should be PRINTABLE CD/DVD STANDARD. The HP Tatto uses the photo paper tray so the printer wants you to close the DVD tray
Posted on Jun 18, 2008
Curtis Richner
  • 461 Answers
SOURCE: Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Posted on Dec 12, 2008
Anonymous
  • 3 Answers
SOURCE: windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Posted on Jan 15, 2009
Anonymous
  • 127 Answers
SOURCE: CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Posted on Feb 05, 2009
I can not print from Windows 7 Microsoft word 2010, the pages come out blank, can print in excel and other office programs just not documents please help have tried everything
Make sure you are installing CURRENT drivers/software offered by HP for your printer for Windows 7. Get it here:
https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-e-all-in-one-printer-series-d110/4023244/model/4023245
Maybe the issue is not printer related. Maybe Word 2010 needs some sort of update. Windows Update will update Windows OS and other Microsoft products (I have a Windows 7 PC running Office 97, Windows Update treats it like Office 2003 and STILL updates it!).
Or, you could manually install them:
https://www.google.com/search?q=word+2010+update&ie=utf-8&oe=utf-8&client=firefox-b-1
Good luck.
Dec 09, 2017 | Microsoft Office 2010
I have ms office 2010 installed in my laptop i dont have the product activation keys.can u please help me to find the keys?
I use the SmartKey Product Key Recovery to find out Office 2010 product key, it is very nice and helpful.
I think you can read this related article and get your solution - http://www.recoverlostpassword.com/article/office-2010-product-key.html
Dec 20, 2010 | Dell Computers & Internet
I inatalled the Avery Wizard software and access to it is not on my desktop or anywhere else. I hvave a new HP notebook runnjng Windows 7.
I suspect that the Avery Wizard is to be used in conjunction with Microsoft Office and its not a stand alone software product in of itself.
1. Go to Avery.com
2. Over on the left side, please find "Template & Software Advisor". It should be the third one down.
Click on this link
3. Click the top "Labels"
4. I clicked "NO" for mail merge options, but you may want yes.
5. Click the top operating system "Windows"
6. Click the top "I'm open to all Avery Solutions"
7. Click yes to install on your computer
8. Please read the message on the far right under "You might like to download Avery Wizard for Microsoft Office"
In other words to access and use the wizard, you need to be in one of the Microsoft Office products like Word and print labels. If you're looking at your destop and you press F1 (Help) with no other applications running, type in "printing labels". Please note that you get to select the vendor such as Microsoft or Avery under the option "Label Vendor".
Dec 17, 2010 | Computers & Internet
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
How can i download microsoft 2010 free
For Microsoft Office installation support, the easiest way is to reach Microsoft customer service. They provide an instant solution for Office setup and install help support.
Services offered-
Microsoft Office Activation Key
Microsoft account setup
Microsoft password reset
Outlook technical support
account live password reset
Microsoft sign in errors
Install MS office
MS Office 365 setup
MS Excel support
Dial directly 1888-315-9712
or visit office com setup
Nov 29, 2010 | Microsoft Office Professional 2007 Full...
How do I get my hp deskjet 6940 to print labels. I'm trying to print Avery 5498 labels
You will have to use software to make the labels...like Microsoft Office Word, Open office Writer, or Microsoft Works. In MS Office Word (2003) go to tools->letters and mailings -> envelope and lables. Create the label you need.
If you use open office, go to File->New->Labels and create the label you need.
After which, you put the paper in the printer and print them out. May want to check out the size so you make sure it prints correctly.
-best of luck
Oct 21, 2010 | HP Deskjet 6940 InkJet Printer
I want to download msoffice2007 software for free
Can't do that, but your other options are:
Download and install Office 2010 beta from Microsoft: http://www.microsoft.com/office/2010/en/default.aspx
Open Office: http://www.openoffice.org/
Mar 09, 2010 | Microsoft Office Professional 2007 Full...
Can i print on printable dvds on this printer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Print CDs
1. Open HP Photosmart Essential 3.5 software.
2. Select Create option.
3. Select Disc Labels option.
4. Select Print directly on Disc option.
5. Choose the Mini CD.
6. Select Choose this format option.
7. Choose the appropriate Design and Photo you want.
8. Click on Create.
9. Under Settings option, select the appropriate printer and Media type.
10. Under Printable Area option, select Standard/Print to hub option from the drop down list under Standard Sizes.
11. Click on Print button.
Jan 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Module compile error
the Avery add in includes a VBA macro which gets compiled. the Avery macro is not compatible with office 2010 because unfortunately microsoft keep changing things so presumably you have installed office 2010. if you could find the offending module and look at the code, then it could be corrected. Avery are pretty POOR to not be able to correct their own code. Microsoft deal with it here https://answers.microsoft.com/en-us/office/forum/office_2010-word/compile-error-in-hidden-module-azwizardmodul/fac4e653-de70-e011-8dfc-68b599b31bf5?msgId=7e73aa04-eb70-e011-8dfc-68b599b31bf5&auth=1 and i must say thats a pretty terrible response from them as their labels creator is AWFUL and its handy to have the avery one. I use the Avery Denison Design Pro 5(free download) and thats useful to have.
Nov 09, 2017 | Computers & Internet
Can I print a cd on my canon mp510 printer?
You need to download a CD cover creator software. If you also want to print your own CD label stickers (round ones for the disk) you will need also to buy CD avery templates.
Here is the software:
Download Super CD Cover Maker v2.0.0
Cd Cover Label Software Freeware
CD Cover Designer 2.5 {freeware} at Damn Printer
Free CD/DVD Covers Software Downloads
Cd covers Free Download
Easy CD and DVD Cover Creator and Label Maker.
Here instead you can buy cd labels:
Avery Labels, buy Avery office products, Avery CD Labels
Sep 06, 2008 | Canon PIXMA MP510 All-In-One InkJet...
HP DeskJet F4280 All In One Printer InkJet Logo
114 people viewed this question
Ekse
efs_perpends
efs_perpends
