Question about LG Dishwashers
Dishwasher won't run much of the cycle.
LD-14AW3
Our dishwasher starts the cycle and then comes up with an upside down FE code. Not sure what that means please help.It is not a strandard FE code which refers to excess water. The F is upside down and is followed by a regular E.
Posted by dljones528 on
Anonymous
    New Friend:
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Posted on Sep 17, 2010
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
Gives me a FE just after I switched it on
Hi there Elshaddia the code FE relates to the machine not being level. please check that it is level and not leaning forward as this would bring up that fault code. please let me know if this helps, regards Gary.
Sep 07, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Our dishwasher keeps stopping its cycle and saying 'OE' It is LG - LD/141ST1
the 'OE' code means clogged or kinked drain line. You will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. Be sure the hose isn't kinked.
Sep 22, 2010 | LG Dishwashers
Getting error code 0E on LD-14AW3 model dishwasher after 2 minutes. Checked drain hose and water seems to be coming out but won'y go any further in cycle Also makes a loud humming noise when running.
To little info, but looks like pipe is much to low. Not getting the opportunity to fill up properly.Raise it higher.(Im asuming that you can hear the drain pump run and water is being pumped out as wall.
Aug 09, 2010 | Dishwashers
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Mar 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
214 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
