Haier HL42E LCD TV Logo
Jim Wightman Posted on Jan 26, 2010
MY HAIER HL42E TV WILL NOT TURN ON. IS THEIR SOME WAY TO FIND OUT IF WHEN IT TRIES THE POWER BUTTON LIGHT FLASHES 13 TIMES IS THIS A CODE TO TELL WHAT IS WRONG WITH IT OR WHAT?
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Oct 20, 2011
SOURCE: my haier tv model no. hl42e wont come on
Hello
If its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.
If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
My haier tv model no. hl42e wont come on
Hello
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Need code to set dish remote control for Hair tv HTFR20R21------FDA/DHHS
We would be happy to help. We currently do not have any codes specifically for your Haier TV, we would recommend performing a power scan. If there is a code that is compatible with your TV the power scan will find it.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sony kdl-40x3100 turn tv on picture comes on for 3 sec then standby light flashes 13 times .please help
The tv have a power supply board have the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I have a haier tv that is only 2 yrs old and the power won't come on the tv. Is there a reset button or someway i can fix it myself.
Reset the tv by unplug,replug it in an hour later.Same problems,power LED light indication flashes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Need three digit code to access DISH network remote for a Haier HL19R1a
We would be happy to help. We currently do not have anycodes specifically for your Haier TV. We would recommend performing apower scan. If there is a code that is compatible with your TV the power scanwill find it. Power scan instructions:
Step 1:
Step 2:
Step 3:
Press the Up button once per second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
After doing the power scan please remember to put the remote back into SAT mode.Thanks so much for being a valued DISH Network customer!
Phillip Chang
4helpful
I have a Dish Network 20.0 IR remote. How do I program it to work with my Haier TV?
duckie715
We don't have any codes available for your Haier TV, however, I have provided instructions on how to perform a power scan to locate a code the operate your TV.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button (SAT) until all mode button backlights illuminate, then release.
    2. Press and release the Power button.
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
2answers
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
5helpful
5answers
Remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
