Dell 922 All-In-One InkJet Printer Logo
Question about Dell 922 All-In-One InkJet Printer
The color cartridge carrier lid will not snap shut when loaded with a new cartridge
Posted by edibac on
Anonymous
    New Friend:
My ink cartridge lid wont close after replacing ink and i have clicked down the cartidge.
Posted on Feb 28, 2010
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
2helpful
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
How to replace ink cartridge
1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Lexmark X1150 - how do I change ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Thanks.
Where do tou install ink
From the Manual:
1 Make sure the printer is on.
2 Lift the printer (scanner unit) until the scanner support keeps it open. The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of the cartridges.
NOTICE: Do not touch the gold contact area on the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the printer (scanner unit) until it is closed.
2answers
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
busy.
the cartridges.
7helpful
How do I change the ink cartriges in my printer
1.Turn on your printer.
2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
3.Press down on the ink cartridge lever to raise each ink cartridge lid.
4.Remove the old ink cartridges.
5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
6.Snap each lid closed.
7.Lower the scanner base unit until it is completely closed.
Enjoy printing...
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    2answers
    Dell Photo All-in-One Printer 944 cartridge carrier malfunction
    Nobody fixes ink-jet printers anymore.
    If the old cart will go back in OK, it could be a bad cartridge.
    2helpful
    Replace ink cartridge
    The print cartridge carrier moves and stops at the loading position.
    5 Remove the stickers and transparent tape from the bottom of the cartridges.
    6 Insert the new cartridge. Make sure the color print cartridge is
    secure in the left carrier and then snap the lid closed.
    If you are installing a black print cartridge, make sure that it is
    secure in the right carrier, and then snap the lid closed.
    Top Dell Office Equipment & Supplies Experts
    Marvin
    Marvin
    Jaime Hernandez
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
