Question about Mitsubishi WD-Y57 57" Projection HDTV
Blinking orange lamp light
The lamp light is blinking orange
Posted by deslynn001 on
Anonymous
  • 59 Answers
If the lamp light is flashing and the tv won't come on you need to replace the lamp. check your owners manual for how to do it or call mitsubishi customer service
Posted on Jan 26, 2010
Mitsubishi dlp tv wd65837 wont turn on.
Hello Ejaz,
You will also probably need to change the blown fuse for the lamp also located near the lamp. The blinking orange led is just showing that the circuitry cannot sense any light output yet!
Good Luck!
Rich Lilja
Mar 26, 2015 | Mitsubishi Televison & Video
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
My television blinks an orange light then turns off
Chec for ground, or a short circuit.Same Lamp?
Nov 01, 2012 | Mitsubishi Televison & Video
Replaced lamp but lamp light still blinks orange
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Orange blinking light and no image. Fan on but no
make sure the colorwheel is spinneng. if it isn't, the lamp won't strike. if the colorwheel is fine, check the lamp for bulges, black spots, fogging or flaking. replace if necessary. if the lamp is fine, replace the ballast.
Jan 22, 2010 | InFocus LP 530 Multimedia Projector
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Aug 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Mitsubishi WD-Y57 57" Projection HDTV Logo
1,224 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
