You need to get a set of RCA leads and connect ya Video to your DVD recorder, from VCR Video, Audio OUT to DVD Audio IN. Press play on VCR, and Record on DVD ya should be good to go.
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Connect the vcr to the dvd recorder via scart. Set TV to your usual dvd channel and power on dvd. Power on vcr and scroll through input channels (AV etc) on dvd recorder until you find the signal from vcr. Prepare the recorder ready to record, then play the vcr and start the dvd to record.
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable. 1
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [K / L], select “Advanced Setting Menu”.
Hit [ENTER].Advanced Setting Menu will appear.
Using [K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [K / L], select “Dubbing Mode”. Hit
[ENTER]. Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication: • After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction. 5
Using [K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit. Make sure to select a recording speed using [REC SPEED]. 7
Hit [PLAY B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP C] to stop the recording. When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically. • Dubbing Mode is available only if the videotape or disc is not copy protected. • You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd. Click Sony Style to select DVD recorder.
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
