Is this model pulse dial? We do not get touch tone.
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
SOURCE: how can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
SOURCE: just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
