Interior lights on ford excursion won't go off, and door ajar symbol stays on dash. have to disconnect battery to turn off. Today kept slamming door until it finally went off.
One of the door switches is not showing an open contact. Which sugnals the computer that a door is ajar. Try blowunyg comoressed air into every door sqitch including the rear hatch. Afterwards, spray each switch with WD-40. Good Luck.
A thumbs up would be greatly appreciated if this answer is helpful to you.
Well, the lights on our 1998 Ford Taurus stay on for a 'limited' amount of time, say 20 minutes and automatically turn off, even if the door is left open or if the glove box light is left on due to a door left open.
I wonder if your body control computer is faulty in your 2004 Excursion?
Or, if the body control computer is fine, and it doesn't have this feature, then I would see if the door latch switch needs to have wd-40 sprayed on it.
We have a 1999 Ford Expeditioin that had this problem with the door open light going on when the door was actually closed. The tech sprayed wd-40 on the locking mechanism and the problem went away.
You have a door ajar switch sticking in one of the doors. Start with the drivers door,open door and spray a liberal amount of WD40 into the latch on the side of the door. Then open and close the doors firmly several times. This usually unsticks them.
If I am not mistaken, the plunger is located in the door with the latch. Most of the time you can just pull the door panel off and adjust the switch. After opening and closing the door, they get knocked out of adjustment. I sincerely hope that this helped you. Take care and best wishes.
Bryon
Check Body Control Module OF Vehicle. This Module Acts As A Switchboard commanding on or off of what ever function inside of vehicle you turn on, wipers, blinkes interior lights etc, possible ground wire to or from control module or possibly bad module!
Lube your door latches. One of the door ajar switches are sticking . Use wd40 or some othe spray lube . Spray into the latch and open and close doors several time.
