Question about Pitney Bowes Office Equipment & Supplies
Imagistics SX 2100. When you change the drum what
Imagistics SX 2100. When you change the drum what steps do you take to remove the "chnge drum" from the LCD.
Posted by gary gerstenhaber on
Anonymous
  • 18 Answers
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Posted on Jan 26, 2010
Shows status offline wont print
Replace with a new drum, clear your print que. reset network and printer
Aug 20, 2015 | Canon Genuine Oce Imagistics Fx3000...
Splotches in prints from our SX 1480
This is actually a Muratec machine. This is not an uncommon fault and it is ALWAYS a faulty toner cartridge. Although you say you have changed it, I doubt you have replaced it with a new one.
Change it I can guarantee it will cure it. I know as I am a muratec engineer!
Jan 27, 2014 | Pitney Bowes Compatible Imagistics / OCE...
Reset Imagistic 2700 Drum Counter
Try this:
http://www.shopping.com/imagistics-ix2600-drum-counter-reset/products?sb=1
Please rate my solution.
Thanks for using FixYa.
Jun 23, 2011 | Computers & Internet
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this...
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Jul 28, 2010 | Panasonic DP-8020E Black and White Copier
Imagistics im3511 copy problems
There are several things that can cause this. The easiest thing that you can fix is to make sure the presuure is on in the fuser. Open the left side door. The fuser is the hot part at the top.right. There are two tabs, one at the fron and one at the back. Make sure these are LOOSE. If they are locked down it removes pressure from the fuser and it will smear the copies. The other things that can cause this are drum wear, bad or worn developer, etc, but those need a technician to change.
Dec 08, 2009 | OCE Office Equipment & Supplies
Imagistics 2500
With that model I believe you have to leave the toner door open and press start
Oct 24, 2008 | Brother MFC-8220 Fax
2,831 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
