Texas Instruments TI-83 Plus Calculator Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have new batteries in my calculator and it is not turning on. Every time i turn on the calculator, there is a horizontal line that appears on th screen.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jan 28, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671821
Points
21595
Ok there is a line, but can you do something with the calculator?
Try to reset the RAM to clear any graphics you might have created.
To reset the RAM \
Press [2nd][MEM][7:Reset][1:All ram][2:reset] ENTER] [ENTER]
Press [CLEAR] to erase the "Ram Cleared" message
Here are some steps to perform in the order they are presented. (Skip point A if you want). Please read the post till the end.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI Web site.
  • A USB mini A to mini B cable to connect two units.
  • An I/O cable to connect two calculators through their I/O ports.
2answers
Voyage 200 pixel line problem
GUEST... thank you very much.. works fine with my voyage ;)
1helpful
My screen is blue when ever i change my batteries, So I Press the 2nd button and make it lighter. But the pixels dont lighten all the way And when i go to some type of menu like for Zoom, there are...
Try to reset everything to see if that helps. If it doesn't , you can try to upgrade your operating system on the calculator to see if that helps to make it go away.
If that doesn't help try this:
"Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message."
Let me know how it goes.
When I try to turn on the calculator, nothing but a straight horizontal line appears on the screen.
Hi
the HP 48g+ is similar to TI83 Plus
the same problem also in the TI its an hardware failure
if you want to fix the calc let me know
[email protected]
Jack
TI-83 Plus calculator: Only a line appears
Try the following steps before thinking of repairs.
I am inserting a copy of an earlier post to a question similar to yours. Please read the post till the end.
C. Third option
D. Last option
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
13helpful
2answers
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
3answers
1helpful
2answers
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
