Hitachi CP-S335 Multimedia Projector Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HitachiCP S335- Filter was cleaned when 100hr message appeared today. Tried to reset ?like usual but it won't give the choice to ?reset to Oh?. Changed batteries -changed remotes to another classroom hitachi remote. Held over reset for over 3 seconds doesn?t help . Usually when going to reset it allows you to use arrow to right for "0h" but that option isn?t available. I went thru advanced menu -got to filter options- filter reset/cancel but when you try to hit the reset it again will just flip mirror screen image to upside down. Turned projector off and on numberous times hasn?t helped. Filter removed, re-cleaned and reinstalled numberous times. Then tried advanced settings to reset ?all configurations? and it "flips the screen upside down too" after appearing to blink and twitch alittle. Has 104hrs on filter - 400 hrs on lens. Any ideas?
Anonymous
Level 2:
New Friend:
  • Expert 144 Answers
  • Posted on Jan 31, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
144
Questions
0
Helped
57892
Points
221
There should be a reset buttton to press at back of the projector press with a pencil.
  • Joshua Black Jul 05, 2011
    Negative ghost rider, the reset for the air filter is on the filter timer on the on screen menu. scroll down to the filter timer and hold the left arrow for 3-5 seconds. a new menu will pop up and ask if you want to reset. push the up arrow and Viola! timer reset
2answers
What's the best oil for Honda em 400 power generator?
S.A.E grade 10w-30 multi grade oil its recommended from 60F and up.
For temp lower than 60F use the 20W oil
if its a new Gen(first operation). replace oil after 20Hr.
Other than that in normal working environment replace oil evry after 100Hr.
Dusty area shorten the time of replacing oil and cleaning air filter.
remember not replace hot oil or if the Gen runing !!
Air filter message on screen
Check your user manual (download if not available) under "cleaning the air filter". It will give instructions on how to reset the filter and remove the message.
5helpful
3answers
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
How do I change the filter on my CP S335 projector. It is saying no air flow.
WARNING ?Before caring, make sure the power switch is off and the
power cable is not plugged in, then allow the projector to cool sufficiently. The
care in a high temperature state of the projector could cause a burn and/or
malfunction to the projector.
?Use only the air filter of the specified type. Do not use the projector with the
air filter and filter cover removed.
?Avoid wetting the projector or inserting liquids in the projector. It could result
in a fire, an electric shock, and and/or malfunction to the projector.
CAUTION ?Please replace the air filter when it is damaged or too soiled,
and also when you replace the lamp.When the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the air filter becomes clogged by dust or the like, internal temperatures rise and the power may be automatically turned off for malfunction prevention.
1. Turn the projector off, and unplug the power cord. Allow the projector to cool for at least 45 minutes and prepare a vacuum cleaner.
2. After making sure that the projector is cool adequately, slowly turn the projector so that the lens-side is facing up. Please be careful for a projector not to fall. While the projector is placed lens-side up, hold the projector.
3. Putting a finger on the filter cover's knob, slide the filter cover in the direction of the arrow to remove it.
4. Holding the air filter's knob, pull the air filter off.
5. Apply a vacuum cleaner to the vent of the projector for the air filter. And then slowly turn the projector bottom up.
6. Apply a vacuum cleaner to the air filter and filter cover.
Please replace the air filter when it is damaged or too soiled.
To prepare a new air filter, contact your dealer and tell the air filter type number = NJ09702.
An air filter of specified type will come even with the replacement lamp for this projector.
7. Position the cleaned air filter or a new air filter into place, and push the points
of "PUSH" word with claws to fix the air filter.
8. Replace the filter cover and snap it back into place.
9. Slowly turn the projector so that the top is facing up.
10. Turn the projector on, and reset the filter time using the FILTER TIME
function of OPTION menu (?37).
NOTE • Incorrectly resetting of the filter timer (resetting without replacement,
or neglect of resetting after replacement) will result in incorrect message
functions.
28helpful
2answers
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
1helpful
My projector nec mt 1075 asks me to clean filter. How do i do it?
All you need to do is use a vacuum hose to vacuum the dust that collects on the filter. The filter cover is on the side of the projector with horizontal slits. You can vacuum through the slits, or remove the cover and carefully vacuum the filter itself. Then go into the menu and reset the filter timer. Find this reset button in the "setup" menu item. Then your clean filter reminder won't show until another 100 hours of usage.
A message appears when I turn on my P990i...
try 0000 (only 4 digits) not five.,..
ive tried before and its success
14helpful
2answers
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Air filter
I have the very same problem.
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
