Try to dowmload recovery firmware from here:
http://www.teac.eu/no_cache/hifi-audio/support/mp3-player/mp-114/?sword_list[0]=mp114
After decompress it, run factory4.exe the connect device to USB.
Use first check device function and then firmware upgrade.
I hope your teac will come back to work fine again.
gylacz
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
