Question about Casio G-SHOCK 200M DW5600E1V Wrist Watch
Time has disapeard on the face of the
Time has disapeard on the face of my g-shock watch the watch..cannot get it to re-apear
Posted by johnklee2 on
David Tolond
    President:
  • 2,501 Answers
It could be a dead battery. Take it to a watch shop and have it replaced.
Posted on Jan 26, 2010
How to set time in g shock wr 20 bar
"G-Shock WR20BAR" could mean hundreds of different G-Shock models. If yours is an all digital G-Shock, the answer is fairly simple. When looking at the watch face, the upper left corner button is the "ADJUST" button. Press and hold the ADJUST button for a couple of seconds. You should start to see something flash on the display. Some models will have many options to select in ADJUST mode. To scroll through them, press the MODE button, which is in the lower left corner. You set the hour, minute, seconds, month, date, and year each separately. When you are done, press the ADJUST button again and you'll be back to normal time keeping.
If you want to learn more about your G-Shock, there is something called a "MODULE" inside it that is the brains of the watch. You can find that on the back of the watch, outlined in a rectangle. Usually a 4 digit number. You can download the manual for your watch using that number, if you enter it on a CASIO website:
http://support.casio.com/en/manual/manuallist.php?cid=009
Dec 28, 2017 | Watches
My casio watch say close on the face
Can you send a picture of the face and the reference of your Casio Watch?.
At TicTacArea.com we can help you out with any Casio watch related problem. We are Casio watches official dealers. Casio Shock Watches
Apr 09, 2014 | Watches
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
How do u set the time on a ga 100 g shock watch
You hold down the A button for a few seconds until it beeps. The A button is the one that says 'adjust' on it and is at the top left hand corner of the watch face. After that you adjust your home city time by pressing the bottom right hand button. After you hit adjust again the watch face will rotate to the home city time. You can see your home city change in the bottom right hand lcd display. A description of the home city codes is in the manuals you can download from the site posted above
Jan 10, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have a g shock wr20bar & my time doesnt want to change how do i change it ?
press the upper left buton for 5 to 6 seconds the setting of time is apear
Nov 21, 2010 | Casio G-Shock G2600 watch
Watch is blank/not charging
The watch started working by itself.
Jan 18, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Mar 10, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Casio G-SHOCK 200M DW5600E1V Wrist Watch Logo
56 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
