Be very carefull of refilled cartridges as they can damage the printers ink system I would suggest remove all the cartridges open rear access door check between the rear access door and front that no peices of loose papers then whipe off the rollers with a semi damp cloth. close all the doors and power up the machine without the cartridges in then pull out the power cable from the back wait for 15 seconds and plug back in and power up insert the cartridges when the printer prompts for them and test
Try to reseat the ink cartrage you replaced it probably is not seated properly.Then restart the printer.
