Question about Aquacal HEAT PUMP 120,000 BTU H135 -
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Posted on Jan 26, 2010
Sep 25, 2014 | Pool & Spa
Jan 26, 2014 | Aquacal HeatWave
Jan 13, 2014 | Pentair Pool & Spa
Nov 30, 2013 | Aquacal HeatWave
Aug 30, 2013 | Aquacal HeatWave
May 05, 2011 | Aquacal HeatWave
Oct 27, 2010 | Aquacal HeatWave
May 02, 2011 | Aquacal HEAT PUMP 120,000 BTU H135 -
1,345 people viewed this question
the barb split and broke off what looks like a nut which is connected to the top of the heat exchanger.
