If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button
2. Then dial ** (star, star)
3. Enter the password (usually 1234)
4. Press 'Next' until you get to 'Ext Name'
5. Press 'Enter'
6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is)
7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters.
8. Press 'Enter' then you are all done... pick and hang up the handset.
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
SOURCE: How do you cancel night mode on the KX T7630? Or
If it's enabled on your phone, on the intercom dial *7800 That puts the system in DAYS. *7801 puts it in NIGHT. By default extension 101 or the main phone has access to it. We turn it on for everybody in most offices by Class of Service options.
Carl
SOURCE: how do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
