Question about Car Audio & Video
Inputing Code into Renault Clio Stereo
My friend has a Renault Clio and needs to type in pin number of her steroe to get it to work again after getting a new battery. She can get the stereo to display CODE but unable to get it to change to numbers 0000 for inputing the code, any ideas?
Posted by austin42 on
xxxxxx xxx
  • Car Audio & ... Master
  • 5,023 Answers
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote  Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Posted on Jan 25, 2010
2answers
Renault clio free radio code
Hello , well there is a link http://www.renault-radio-codes.com/renault-clio-radio-code.php , enter your Renault serial and you're cool ;)
Radio has reset due to flat battery
need to notify dealer for code but call first they can also advise how to get radio id number which also will be needed
1helpful
Had to install a new battery in my clio and now the radio is dead, the clock is working tho
you ned to go to bye store renault and re istall code for the stero thay can get teh code and istall it .
2helpful
2answers
My car stereo is locked
There should be a Renault security code somewhere on the radio in the format TOA123 otr TA123 or just A123 at the end of a barcode.
Then POST A NEW QUESTION
quoting this security number and the other Serial Numbers and you should get a free code fairly quicky
2answers
I am looking for a radio code Renault Clio
phone Renault Center they are the only one to help you.
I have a renault clio and ive just bought a new
Not an expert on car stereo but a friend of mine has a business doing install and did our car....i think what you are looking for is an 'iso' connector for your particular head unit.....this, kind of does all of the wiring for you....does that help
Renault Clio locked radio!!
Take the stereo out of its place and check the label underneath it.
1helpful
2008 renault scenic cd code
when the battery is changed the cd loses its code. to retreve it get the chasiss number. its located on a plate inside the drivers door. its starts with VF!. ring your renault dealer with this number and they will give you the 4 digit code and instructions on inputing it. obviously write it down in case you need it again
Car Audio & Video Logo
Top Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
