Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
How do I change the optical block in a sony tv
Posted by amirtavani on
SALMAN NASEER
    Genius:
  • 1,011 Answers
Disconnecting wiring from power supply block
This step may be optional, if power supply block must be transferred to purchased replacement optical block. Undo the blue plastic-coated wire holders to release the two wire bundles. Disconnect the connectors shown with the dotted lines in the photo below. One, which presumably provides power, is disconnected directly from the power supply block, and the other is a regular wire connector.how do I change the optical block in a sony tv - a837b7e.jpg
Disconnecting the optical block fan wires
how do I change the optical block in a sony tv - 442a9a3.jpgthe optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
how do I change the optical block in a sony tv - eec81e6.jpgdisconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to ship. I recommend adding specific protection for the projection lens, then sealing the whole unit in a bag to prevent infiltration of dust or packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
how do I change the optical block in a sony tv - moz-screenshot.pngicture of a replacemehow do I change the optical block in a sony tv - moz-screenshot-1.png the KF-60WE610. Note that some parts of the old optical block need to be removed and installed on the replacement block.
Posted on Jan 25, 2010
  • SALMAN NASEER Jan 26, 2010
    here are the remaining picture that were missed due to some problem.
    The
    following two pictures show a replacement board that also needs to be
    installed on some models (including at least some KF-60WE610's). Note
    that this board is installed in a different part of the TV (probably
    near the audio-video unit/chassis), and that many models do not require
    this separate board.
    best of luck....
Anonymous
  • 59 Answers
That is a difficult opperation you would really need a service tech to do it or if you are very good a taking things apart pay close attention to how you do it the optical block is in the middle of the tv behind everthing you have to remove th back then carefully take out the insides not something I can really desrcibe try looking on you tube for a video tutorial
4 Related Answers
Anonymous
  • 105 Answers
SOURCE: optical block
the optical assy is a large amount of work i wouldnt recomend doing it yorslf at all. please leave that to the pros. you have to completely disassemble the tv from the back. i can do it myself in about 45 min.
Posted on Oct 13, 2007
Anonymous
SOURCE: sony 50we610 optical block
hi there how much you want for the optical block thanks [email protected]
Posted on May 16, 2008
Anonymous
  • 10594 Answers
SOURCE: Have a Sony TV modelKDS-R50XBR1 and after changing
Required optic block part number is A1148155A for KDS-R50XBR1, commonly calls light engine. Available HERE and HERE.
Click above links for price info.
Thanks.
Posted on Jul 30, 2010
Testimonial: "Thank you. This is exactly what I am looking for. Cheers!"
After replacimg bulb tv still flashing red
we bought our Sony Wega in 2006 - we changed the bulb twice both times they exploded; we threw this tv out one month ago - sorry but its literally GARBAGE! within the first year the optical block went, then the replacement under my extended warranty that optical block was defective-within a month all the purple hues started showing up again - warranty over - never will I purchase a 4,000 tv nor any sony products ever again! the only good product I ever liked of sony was the Walkman!
Is there anything like optic unit for sony kf 50e200a
If you are refuring to an Optic Block then yes. This is the heart of your Television. It controls all of the color and projects the image out to you. i believe this model uses 1 of 2 different Optic Blocks. So if you are going to change one, you need to know which one is in your set.
3helpful
Thanks.
1helpful
2answers
Sony KDS-R50XBR1 optical engine problem
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
4helpful
2answers
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
3helpful
We have bluish spots on our picture. It's not the lamp. We had them before and after we changed it.
This is an inherent issue with the optical block of your TV. It was an design flaw in the TV that is only fixed by replacing the optical block. This is the most expensive part in the TV and is very hard to replace.
Part number: A-1084-660-A
List price: $552.39
Core Charge $1060.00
Sony did extend the warranties for the optical blocks of this model until Dec 31, 2008. Try calling Sony to see if they will pay for at least part of the repair. You will need a technician to come out either way to replace the part as you need to take the whole TV apart to get access to it.
2helpful
2answers
GHOSTING
Hey joseph, actually replacing the optical Block is not necessary at all, all you need to do is get into the "Service Mode" of the Tv and change a few setting around, did it a few weeks ago and now my TV looks perfect, no reason to waster $1200 as sony is trying to get over on all us consumers.
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Optical block
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
