Question about Foxconn CPU Cooler Fan CPU Fan
I broke my cooler :(
There is 3 wires coming from cooler, red, black and yellow. My yellow wire snapped, how can open this cooler to fix this?
Posted by xray_cm on
M
    New Friend:
  • 81 Answers
You can solder the two open ends of the wires/base together. Generally, it doesn't hurt at all to have the yellow wire not connected. As long as the fan is still running, you will be fine. The yellow wire gives information about the fan RPM. You just won't be alerted if the fan stops working.
Posted on Mar 08, 2010
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
I just spliced open the wire coming out of the camera.it only has 3 wires.they are black,red,and yellow. so now i dont know witch goes where? need some help..
red & black is your power + & ground -. Yellow and black is your video and ground. you probably don't have audio if there is not another wire. If you have a shield wire around the others sometimes that is used for ground and in that case red and shield wire would usually be the power.
Feb 17, 2015 | GE 45231 Home Monitoring Camera
Wiring
Technical Documentation Support Overview
On the support page choose the SFSQ-LF info and open the PDF download. The black on the fan unit goes to the black feed from the box. the Red on the unit goes to the light. The Yellow goes to the Fan.
Feb 05, 2014 | Lutron Electronics SFSQ-LFH-WH...
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Jan 16, 2010 | Avanti EWC-12 Wine Cooler
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
Foxconn CPU Cooler Fan CPU Fan Logo
144 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
