Question about Bosch HBN 430560B / 430520B Single Oven
My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
Posted by colin_sefs on
Barry Coates
  • Bosch Master
  • 3,463 Answers
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
2 Related Answers
Anonymous
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Kevin White
    • 1902 Answers
    SOURCE: Zanussi ZDF 290XC Double Oven and Grill. Grill
    Hello & Welcome to FixYa
    This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
    Kevin
    Posted on Aug 30, 2011
    Bosch oven temp control
    If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
    Mar 23, 2013 | Bosch Ovens
    Smeg oven UK80MFX1 troubleshooting
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Nov 30, 2011 | Smeg Ovens
    Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
    Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
    Feb 11, 2011 | Ovens
    I have just moved and the oven is a bosch. I do not have any directions. The top oven and grill works OK but the main oven does not get hot. I can hear the fan but even when the oven has been on for an...
    If the fan is working o/k, then it is probably the oven element that is faulty.
    This is located at the rear of the oven compartment behind a removeable cover.
    Nov 22, 2010 | Bosch Ovens
    Can I change the grill element myself? I assumed it just plugged in at the rear and have removed the two screws holding element to top of oven. Now I wonder if the steel plate at the back is itself bolted...
    The grill element is not usually a 'plug-in' device.
    You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
    Remember to switch off the power before removing the back.
    Jan 12, 2010 | Bosch HBN 131560B / 131520 hot-air...
    Oven problem
    Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
    If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
    These are the possible reasons for it to heat up slowly.
    Plz rate my solution.
    Thanks.
    Jan 25, 2009 | Ovens
    Oven not getting hot
    The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
    Access is by removing the inner rear cover of the oven, there you will see the element.
    Replace with a new one.
    It is possible the base element is faulty in the top oven of the Hotpoint EW95,
    The other possibility is that the high speed grill element is only part working.You need to check both these elements.
    If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
    If it does heat, then it could be a faulty thermostat or possibly selector switch.
    Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
    Thanks.
    Dec 26, 2008 | Ovens
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    No heat?
    hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
    Feb 29, 2008 | Bosch HBN 131560B / 131520 hot-air...
    Fan oven not heating, bosch hbn 202t
    the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Bosch HBN 430560B / 430520B Single Oven Logo
    1,280 people viewed this question
    Top Bosch Ovens Experts
    Marvin
    Marvin
    Michael Thomas
    Michael Thomas
    Paul Carew
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
