Watches Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a relic trail watch. I need to get a description of the function buttons. Mostly I need to be able to turn off the watch alarm.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
828
Points
I had the same problem. Apparently new watches aren't sold with instructions. They have instructions online for generic Relic styles at www.relicbrand.com, sort of. They are too cheap to take the time to print instructions out and give generic styles. Good luck!
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 25, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813182
Points
13579
Relic is made by Fossil. Find Fossil watch manuals in My tips and tricks her on FixYa.
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
28helpful
How do I turn off the hourly chime on the Timex 1440?
Use the mode button to toggle to the alarm function. Once at the alarm function, press start/stop. It wil turn the alarm on or off as well as the hourly chime.
3helpful
I have the Speedo Kids Active Swim Watch and cannot remember how to turn on/off the alarm and set the alarm. Please help!
You might find this pdf helpful - it gives a basic description of how 4 button watches can be set.
www.buydakotawatches.com/PDF_FILES/Digital.pdf
Sep 10, 2010 • Watches
Relic model zr66023 165 ft under water watch. how do you light the light to see numbers. 2 buttons on side, buttons on side push in but no light
This particular watch has no light. The two additional buttons are for the chronograph (timer) function. The top is the stop/start button, and the bottom is the reset button. Source: I own this model of watch and have the book on it as well.
5helpful
Need to know how to set the time on my watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 27, 2010 • Watches
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
3helpful
Resetting time on relic watches
Press and hold the Mode button - upper left. At first, it will display the stopwatch function. Keep holding until it goes to flashing alarm set mode. Once it starts flashing, release the button and then immediately press it again and release it (do not hold it the second time). Now you are in time set mode. You can change the time, starting with the seconds, by pressing Adjust - upper right. You can move to minutes, hours, day, and date by pressing Alarm - lower right. Pressing Mode again will exit the set function.
Jul 09, 2008 • Watches
2helpful
2answers
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
