How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
