Computers & Internet Logo
Robert Melton Sr. Posted on Jan 25, 2010
I have a network issue. when I log onto my home network I continue to get kicked of momentarily as it states that "Windows was unable to find a certificate to log onto the network Melton1 which is my home network. Anybody have any ides to get rid of this very annoying isuue? Thanks so much, Kickerone
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
105
Points
When i try to go to the big "e" you know, to get on the internet, it freezes up, and you can't close out, you try to just go again, and that one freezes up too. The only way to get it off is to restart the computer, and that may or may not work. does anybody have any idea what that could be?
Experincing network problems cant load data...cape town
* Too many issues for just a simple answer.
* If this is a work place; contact your I.T. manager or service.
* If this is your home then check the following; Connections, router, computer (clean up), internet service providor.
*** following is for information only.***
* Pull the power on your internet router. Count to 10 then power back up. (Resetting router.)
* Clean up your computer. Perform maintenance as instructed in windows ( or mac)
* Too many usere's on network. Kick kids off. Or stop them from streaming video.
* Change your password to router (Wifi) to eliminate unwanted users.
* Check the web site for other download sites (mirror sites)
* Be aware that downloading from "Torrents" are flow restricted by local servers to prevent copy write infringment.
* Perform an update of all required software.
* Check for maleware.and virus.
* Note that browsers need to be updated to continue working.
* Note that some upgrades will not work unless windows is current.
* Note, older computers are unable to load updates due to; lack of memory.
* Note Windows 10 is not supported by Micro soft.
Aloha, ukeboy57
1helpful
I don't have the access point network key. How do I continue to install my new MP640R unit to my in home wireless network?
Plug the router into your pc with an ethernet cable ( unless you can log onto the router wirelessly ), log onto the router and set/change your network key.
If you are unsure how, just google youe router and set up.
When you have your network key from the router you can set your wireless printer up
Internet Explorer freezes when I log onto RTE TV (Ire).
Sir/ Madam -
Please try to use any other browser like firfox or Chrome and see if you are able to stream video. If yes there might be a proble with Internet Explore setting .
Try below steps to fix it --
Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK
Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
Reset Internet Explorer 7 settings loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
Missing network connections
Press control panel.
Select network connections.
Select setup a home or small office connection.
Follow the instructions on the screen.
Unable to log on to network with Apple Laptop
The type of computer doesn't matter, as the protocols are the same. Check your router's dhcp settings, as you may have it set to allow too few IPs to be distributed.
1helpful
2answers
Connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
