Terk XM Commander Satellite Radio Receiver Logo
Question about Terk XM Commander Satellite Radio Receiver
Antenna interface - Sirius to XM, Dodge
I have an 08 Ram that came form the factory with Sirius. I want to install my Terk Commander but use the factory Sirius antenna. Is there an adapter?
Posted by unitedwes88 on
  • John
    John Feb 27, 2013
    Yep, you just have to carefully trim off the outside plastic on the SatRad antenna connector, then it will fit into the Terk receiver jack.
John
  • Terk Expert
  • 509 Answers
Connector should fit - provided that there is ONLY one connector for the SatRad and not two.
You might have to trim off some yellow, or pink or green plastic, but the metal connector should fit.
Posted on Jan 25, 2010
Have a 2007 Jeep Commander. Sirius is intermittent and will flip over to FM frequently
First question is if you ever spilled a soft drink into the radio such that the AM/FM/SAT switch gets sticky?
2nd, do you have any way to pull-out the radio and borrow a magnetic-mount Sirius antenna to temporarily test and see if the antenna on the vehicle is bad?
If passing the first two tests, then it's likely the whole radio unit has to be replaced with a model from a similar year. Actually, the audio quality you get from an XM Onyx will be much better than the Sirius radio in the Chrysler vehicles, and you can just use the AUX input on the radio for playback.
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
2helpful
I have a 2009 Dodge Ram pickup with factory sirius radio. When I put my cab over camper on it I lose the sirius radio signal. Is there a external antenna that will work with setup . I can mount it on top...
We had the same issue with our 2007 Dodge Ram truck. We use an external antenna when we have the camper on. You can buy these at various places on line. Get the car antenna not the home antenna. It magnetically mounts onto the truck so we put it on our hood and routed the antenna wire through the passenger side door. Our satellite box is behind the glove box. Remove the glove box and look up in the cavity. We were able to just unplug the factory antenna and plug the external antenna in. It's easy to switch back too. Just be careful with the antenna wire because it's fragile and any little bit of damage makes it useless.
Could my Terk XM antenna be bad right out of the blister pack?
Yes, it is possible, but go outside and face the SW and try it that way to make sure. If you have an unplugged or bad antenna, if will usually say "CHECK ANTENNA". Make sure you don't have a chunk of metal, or even your hand over the top of the mini antenna, or you WILL block the signal. Let me know how it works for you. good luck!
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
2answers
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
2helpful
3answers
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
