Question about IBM ThinkPad T60 Notebook
I have 0271 error can get into bios but not able to change the date and time??
Posted by huvba on
Lee Hodgson
  • IBM Master
  • 4,810 Answers
The error means that you have to change the BIOS battery first before trying to change the date and time.
As far as i know with IBM's the CMOS (RTC) battery is located under one of the panels underneath the laptop and is usually covered with red, blue or yellow plastic with wires coming from it. Disconnect the battery and replace it
Once the CMOS battery is replaced you can set the date and time and no more error messages.
Regards.
Posted on Jan 24, 2010
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.
When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.
Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
Oct 22, 2012 | Gateway Essential 500 PC Desktop
IBM T30 error 0271
Error 0271 means: Date and time error. Neither the date nor the time is set in the computer. You need to set the date / time in the BIOS.
Jan 02, 2012 | IBM Computers & Internet
T30 keeps giving me an Error 0271
Error 0271 Date and time error-Neither the date nor the time is set in the computer. Run IBM BIOS Setup Utility to reset the time and date.
I suspect the CMOS battery needs to be replaced.
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA! Bestregards,
Junior
Sep 23, 2011 | IBM ThinkPad T30 2366 Notebook
Error 0271 : check date and time settings fan error how to fix this 2 error on IBM think pad 2647-2 TU, it display when turn on the power. thanks alot
Easy way is to run the setup utility and clear the date and time - else go into BIOS and change the date and time to the correct ones. If it keeps reverting then you need to put a new battery in.
Sep 17, 2010 | Computers & Internet
0271 error
go to the bios and set the time and date there. you also may need to load the default settings to reset the bios to remove any bios passwords. if that does not work remove the bios battery or move the bios jumper for one minute. to reset it write down all bios settings befor you do it.
Jun 22, 2009 | IBM ThinkPad T21 Notebook
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad T60 Notebook Logo
415 people viewed this question
Top IBM Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
