Question about Cobra 148 GTL 120-Channels Base CB Radio
Have not used my cobra for some time ...sine someone need my K40 antennae more than me. Just put it back in service with a new magnet mount 36 inch - can send and receive in USB and LSB ....can here in the AM mode ....but cannot transmit out - very little signal?????
Posted by rdiett1964 on
thndr143
    New Friend:
  • 141 Answers
Center the antenna on the vehicle, then check the SWR on channel 1 and channel 40.
with the switch in CAL position, key radio and use the swr/cal knob to set the meter so the needle is just touching the end of the red area on the right-hand side of the meter.
Once calibrated, unkey and switch the switch to SWR and key up again. The lower the reading, the better. If the SWR is Higher on 40, the antenna needs to be shorter.. if its higher on 1, then the antenna needs to be longer.
if it dont transmit period on AM, then there's an internal glitch :)
Posted on Jan 30, 2010
James Walker
    Habit-Forming:
    New Friend:
  • 65 Answers
148 gtls have a very touchy receive they are naturally a quiet radio on am. It could be noone in the area is that close to hear.
Posted on Dec 08, 2014
Dodgem250
  • 68 Answers
I'm not sure what kind of antenna you have, but a 36" magnet mount is not much. I would suggest using a better quality antenna like a Wilson 1000 or something like that. cheap 36" antennas are not a very good investment.
Thanks,
Dodgem250.com
Posted on Mar 05, 2010
Anonymous
    New Friend:
  • 12 Answers
Magnet mounts do not have a true ground.....try grounding chasis of radio to circuit board ground
Posted on Jan 25, 2010
I have the Cobra 29 lx, I hooked up a new antenna the K40 BCMax. Checked the swr on charges 20, 1 and 40 all is good but I keep getting the antenna warning. (New antenna, mount and coax cable) I'm stumped...
Make sure the antenna has a good gound at its base and make sure nothing is touching the whip or the coil and make sure the coil is not too close to anything metal.
Sep 09, 2018 | Cobra Radio Communications
A k 40 magnetic antenna has high swr and wire and everything looks fine
The K40 is known to fail after that many years in service when moisture gets into the coil it causes it to change it resonance freq. and hence the higher SWR. Buy and new antenna and enjoy 10 years is way to long for an antenna to last.
Apr 05, 2014 | K40 CB Antenna K-30
I have a cobra 29 and noone can here me. I have an 18 inch antenna and brand new coax. The mount is on the mirror and the antenna wire goes right through the door to the radio I get rf output power fail...
throw that short antenna in the garbage you are wasting time trying to talk on it. as a rule of thumb your cb antenna should be no shorter than 36" try a longer antenna and see if that solves your problem it should
Apr 04, 2013 | Radio Communications
I have 29ltd love the radio i'm over the road truck. I reasonnly replace my old steel whip center load antenna put 4' k40 top load one.ran new coax 18' grey. I get the red ( ant) light comes on...
Check SWR with a meter, if its 1.1 to 1.5 then its fine no matter what the light says. The light can be adjusted inside to not light up until its very high(Its adjustable with a Variable knob inside) Get a Cb shop to check it out. I'd go for LIL Wilson 500 or 1000 antennas, I hear they are superb.
May 11, 2011 | Cobra 29 LTD CB Radio
I just can't get any range. I drive a company truck so I do not want to modify the truck. It has a standard antenna and I nought the uniden 69 with the weather channel as well. I was thinking of buying the...
Hello cktmn,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
Yes, the K40 is a great antenna for that radio and it should come with the COAX on it.
It is a magnet mount and the best place to put it is on the top of the vehicle or the center of the trunk. You will be surprised as to how well it works.
I hope this was helpful to you and thanks for choosing FixYa today and in the future.
Your comments are always welcomed here.
John
Feb 24, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
Nov 23, 2010 | Cobra 29 LTD CB Radio
I can't get the swr value close to 1 it's over 3 what am i mising
Several things are working against you.
1 Antenna location= Needs to be in CENTER of car or truck, and high. no grounded metal can be next to the element (the hot/positve part of the antenna)
2 the only way to really ground the antenna is by having a flat metal ground plane under the antenna. DC grounding does NOT do this, that is a misunderstanding.
3 make sure you use a tunable antenna. I have found the wilson's to be very easy to tune and performe very well, for a base loaded antenna.
4 in short a wilson or k40 magnet mount placed on the very top of the roof in the center will have a perfect ground plane. Then shorten or lengthen the steel whip to ajust your SWR's. You will get the best results this way. This is the ONLY way to achevie good performace.
5 I will say this the absoulte best antenna is the 102"steel whip, if you got the clearnce and dont mind it hitting tree limbs put it on a big magnet mount with a spring at the base and youll have a perfect antenna. But the wilson is shorter and easier to tune.
May 15, 2010 | Cobra 29 LTD CB Radio
I have a pickup with a fiberglass bed cover, inside is a Cobra 29. When the k40 antenna is on the bedcover (magnetic mount w/ 6x6 inch metal plate glued to the bedcover) radio will give me an antenna...
Well, the k40 is designed for roof or trunk mount,you would not be getting a good ground,plus you would be getting feed back from cab,no good transmit or receive. Get a good 102" fiberglass or steel whip that's bumper mount,mount it on right rear bumper and you will be good to go.
Mar 28, 2010 | Radio Communications
What antenna would you recommend for my cb? cobra 29ltd
depends on what vehicle its going on. If its a car, you don't need anything crazy, unless you are going to run a linear.
You are fine with a wilson 500/1000 mag mount or a k40 mag mount.
just make sure you tune the antenna for lowest SWR.
Sep 29, 2009 | Cobra 29 LTD CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
226 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
