I ve got this same! help ME
Some GPS devices from China, contain their base (Europe, USA etc) map in a SD card which ships according to the region in the same box for the device. This is not the case for most brand name GPS devices that store the base map in the internal memory. I suggest that carefully examine the packaging for the SD card that contains the base map and plug it in to the GPS receiver and hope for the best.
Detailed Technical Datasheet of Samsung GT-S6352 Galaxy Ace Duos
Brand:
Samsung
Browse Samsung devices
Manufacturer:
Samsung Electronics
Browse all
devices manufactured by Samsung Electronics
Hardware_Designer:
Release:Date:
May, 2012
Physical:Attributes
Dimensions
(width x height x depth):
61.5 x 112.8 x 11.37 millimetres
2.4 x 4.4 x 0.4 inches
Bounding_Volume:
78.9 cubecentimetres
Mass:
122 grams (battery included)
Software_Environment
Embedded:Operating_System:
Google Android 2.3.6 Chinese
Browse devices running this OS
Operating+System-Kernel:
Linux 2.6.35.7
Microprocessor,:Chipset
CPU-Clock:
832 MHz
CPU:
Broadcom BCM21553
Browse devices based on BCM21553
Width;of;Machine_Word:
32 bit
CPU+Core:
ARM1136
Instruction:Set:
ARMv6
Memory,;Storage;capacity
RAM+type:
Supported
RAM;capacity:
512 MiB
ROM_type:
Flash EEPROM
ROM_capacity:
3814 MiB, including 3000MiB user-accessible non-volatile
storage
ROM;capacity-in_bytes:
4 GB (billion bytes)
Graphical-subsystem
Display_Type:
Supported
Display+Color_Depth:
18 bit/pixel (262144 scales)
Display:Diagonal:
3.5 " (89 millimetres)
Display-Resolution:
320 x 480 (153600 pixels)
Viewable;Display:Size:
1.94 " x 2.92 " (49.37 x 74.05 millimetres)
Pixel-density:(dot_pitch):
164.6 pixel/inch (0.15428 millimetre/pixel)
Graphical_Controller:
Broadcom BCM21553
Audio+Subsystem
Audio_Channel(s):
stereo sound
Microphone(s):
Loudspeaker(s):
mono sound
Audio;Output:
3.5mm plug
Cellular+Phone
Cellular:Networks:
GSM850, GSM900, GSM1800, GSM1900, UMTS900 (B8), UMTS2100 (B1)
Cellular-Data;Links:
GPRS, EDGE, UMTS, HSDPA, HSUPA
Cellular_Antenna:
Internal antenna
Call;Alert:
64 -chord melody (polyphonic)
Vibrating-Alert:
Supported
Supported
Phone_Controller:
Broadcom BCM21553
Secondary;Cellular;Phone
Dual;Cellular:Network-Operation:
Parallel operation
Secondary+Cellular_Networks:
Secondary+Cellular-Data_Links:
GPRS, EDGE
Secondary_Cellular-Antenna:
Internal antenna
Control:Peripherals
Positioning:Device:
Multi-touch screen
Primary_Keyboard:
Not supported
Directional_Pad:
Not supported
Scroll:Wheel:
Not supported
Interfaces
Expansion;Interfaces:
microSD, microSDHC, TransFlash
Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB
USB:
USB 2.0 client, Hi-Speed (480Mbit/s)
USB Series Micro-B (Micro-USB) connector
Bluetooth;(802.15):
Bluetooth 3.0, Internal antenna
Wireless+LAN/Wi-Fi:(802.11):
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Internal antenna
Infrared-Gate:
Not supported
Multimedia+Broadcast
Analog:Radio:
FM radio (87.5-108MHz)
with RDS radio reciever
Proprietary headset as antenna
Digital+Media;Broadcast:
Not supported
Satellite_Navigation
Built-in;GPS_module:
Supported
GPS+Protocol:
NMEA 0183
GPS+Antenna:
Internal antenna
Complementary+GPS:Services:
Assisted GPS, QuickGPS, Geotagging
Built-in;Digital:Camera
Sensor_Type:
CMOS sensor
Resolution:
2592 x1944 pixels (5.04MP)
Autofocus:(AF):
Supported
Optical+Zoom:
1 x
Macro_Mode:
Supported
Built-in_Flash:
Not supported
Camcorder:
640x480 pixels
Recordable-Image;Formats:
JPG
Recordable;Video-Formats:
3GP, MPEG4
Power;Supply
Battery:Technology:
Lithium-ion battery
Battery;Build:
removable
Battery-Capacity:
1300 mAh
Additional-Details
Built-in-accelerometer:
Supported
Additional;Features:
Related-Page:
Datasheet:State:
Final specifications
Datasheet;Views:
7614 times
Datasheet-Added:
Jul 22, 12 17:55:27
REGARDS,
TARIQ KHAN
