Question about Hayward SAND FILTER, PRO SERIES
We've got some flow and see the pressure gauge surging and even the back flush surges. any ideas?
Posted by fempark72 on
GetMeOttaHere
  • 2,926 Answers
Just an idea....your impeller inside the pump is clogged or defective. Unless you have a leak, this is the only thig it could be. It is surging due to excessive air in the system.
Posted on Jan 24, 2010
Idle surges
surging problem could be vacuum leak check all vacuum hoses on intake manifold.hook vacuum gauge to check engine vacuum could have intake manifold leak or could have bad spark plugs and wires.distributor cap and rotor need replacing.ignition timing off.if all is good clean fuel injectors and change fuel filter.if fuel pressure low or pump failing engine will surge real bad.if your air flow sensor bad or egr valve bad the check engine light will turn on.best have vechicle hook to code scanned check emission control system.many things cause engine surge dirty fuel injector faulty fuel pressure regulator have vechicle code scan to save from guessing spending way too much money.
Nov 19, 2013 | 1996 Acura TL Series
2002 Chevy Cavalier Surge Tank Pressure Cap will not unscrew off.
Hi, Have you tried a product called WD40? it does wonders to get distributor caps running agin in wet weather etc - this may help. I have used it in all sorts of problems - try this.
Feb 19, 2012 | Chevrolet Malibu Cars & Trucks
My h23 dohc v-tec is surging could it be a clogged cadilletic converter
Very low possibility. More likely the fuel injector(s) are worn. They are good for only about 75,000 miles- their expected service life.
if they were recently replaced, check fuel pressure regulator- unplug the vacuum line, or put a gauge on the line and see if it has steady fuel pressure.
If it surges while driving- at highway speed, while throttle position sensor is a possibility- rule out the fuel system. If you have the MAPP sensor, make sure the atmospheric vent is clear, mason bees like these for nesting. If you ahve the Mass airflow sensor- back flush it with contact cleaner to clear the heater wire and the sensor.
A clogged catalytic converter would make acceleration slow, the engine would sound like it was straining, and top speed would be limited.
Feb 04, 2012 | 1998 Honda Civic
Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
Mar 28, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
3.8L '97 Mercury Cougar XR7 Boston LE w/idle surging
try cleaning the throttlebody if that doesn't help unplug the mass air flow sensor and see if it smooths out
Jan 04, 2010 | 1997 Mercury Cougar XR7
2001 2500hd duramax idle surge. doesn't do it all the time. oil pressure gauge fluctuates small amount but RPM stays constant.
Well there are quite a few things that casue a "surge" in a common rail diesel. You will need to check injector flow rates (scanner only). Fuel pressure regulator for pulsing (scanner only). Supply side fuel system for air leaks (seeing if it is sucking air into the system).
My bet would be the injectors, because you say the rpms aren't going up and down, which is usally what happens when the regulator goes bad, and when you **** air into the supply they have an extended crank. Report back with your findings.
Nov 23, 2009 | 2001 Chevrolet Silverado 2500HD
Heater surging
We are a service center for these type of heaters. The most common problem causing surging is the air pump and or the rubber hoses. If the pressure gauge holds steady then it is most likely one or both of the hoses. New from the box we get heaters with the hoses bent and sometimes even rotten. In an emergency you can turn the carbon vanes 180 degrees and put the pump back in service.
Nov 16, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Hayward SAND FILTER, PRO SERIES Logo
199 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
Marvin
Marvin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
