Either contact your local provider directly or BlackBerry technical support here: https://us.blackberry.com/support/contact
SOURCE: jvm error 547 blackberry 8320
try running app loader again but before you connect your phone up to the computer pull the battery out, then connect the phone, then put the battery back in. A lot of times it will force the connection to get established and then you should be able to run app loader.
SOURCE: JVM Error 102
This is a Java Virtual Machine Error with your blackberry OS. you will need to download a BB OS from Blackberry.com and then runn Apploader from your Desktop manager software. This will wipe and replace the BB OS and fix the issue.
Sometimes a Hard reset can fix this issue though.
If you need further help, please visit www.blackberry.com/btsc
SOURCE: How to manage BlackBerry Curve 8330 calendar from home PC desktop
The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
SOURCE: my black berry goes off on its on,
try taking the prongs that the battery touches and lightly bending them out a bit for a better connection. also make sure the prongs are not corroded. If they are, you can clean with cotton swab and rubbing alcohol.
SOURCE: JVM error 102 on curve 8310
Invalid code in file system problem exists with one or more COD files.Please reinstall your operating system
blackberryrocks.com/.../official-os-450124-8300-8310-8320-indosat/
try these links to see if this is what you are looking for..
