Knicked this from a forum site:
"I don't know if it's coincidence but I was having the same problem.
When the error message came up it said that I should check my internet
settings. So I went to wii options-->wii settings-->wii system
settings 2-->internet-->agreement/contact.
I
re-accepted the terms and conditions for the shopping channel and then
went to try the update again. It worked. If you are still
experiencing problems with the update you might want to try this."
The fault is with the update not the console so don't worry too much
This is a common error...you can fix your error using wii repair guide..click here for your reference...
Error
Code: 32022
Please try your
connection again later
The Nintendo Wi-Fi Connection servers appear to be down for
maintenance. Please try your connection again later.
If you have waited several hours but are still receiving this
error, please call 1-800-255-3700 for assistance.
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
SOURCE: Have just tried to connect the wii tothe internet
to connect the wii to the internet you go to wii settings then find internet then there should be connections use connection 2 and set it for wireless then search for your router then input the security code which is on the back of the router which is wpa-psk or wep key then start the search then it ll upgrade then jump back to the wii main menu then you should be able to access the wii s online features
SOURCE: Can't update the Wii.
Here is a link for your error code.This one looks very strange.I though I was offline and re-entered it lol.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=32022&system=Wii&locale=en_US&action2.x=19&action2.y=27
Good luck and game on!
SOURCE: an error a occure. unable to perform the wii
According to Nintendo this means that Nintendo itself is doing system updates. They do list a phone number if the errors continue. Here is the link for both. If this helps can you please rate me. I do not get paid for this but I worked in an electronics store for 13 years and like helping people.
SOURCE: an error has occurred on
it just means that nintendo servers are busy try in a few hours or at a time that you think there will be less people online
Error Occurred. Press the Eject button and remove the disc.
Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC
adapter's AC plug from the power socket. Next, check whether the disc is dirty
or scratched. If it is dirty, gently wipe with a soft cloth from the center to
the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into
the power socket and turn the console power on.
If the same message still appears, the Wii console may be damaged. Turn
the Wii console off immediately.
Click here to download Ninento wii repair guide
