I got the env touch around Aug. It was fine when it would die, I would charge it. About two nights ago I went to charge it and plugged it it and it shut down. It kept trying to turn back on but then stopped and shut down again. I thought i would need a new battery so I went to Verizon a couple days after that. They gave me a replacement phone, still the env touch. It worked fine. I was texting people when the battery was going dead. I turned it off and when I got home I chared it. It did this again and shut off the phone. Now it wont turn on no matter what. Do you think that it's the charger? Also, Do you think my phone is ruined now? Please help me as much as you can on this. Thanks.
SOURCE: enV
i think ur phone has a manufacturing defect call verizon and tell them unless u have had it 4 over 30 days and dont have insurance but u can always try.......sry i cant help more
SOURCE: broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
SOURCE: how do you dismantle the end of the charger?
Absolutely not. You must use the LG charger, or you might get an improper amount of current into the phone and toast it.
SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
