My brake went out, cylinder broke and shoes were shot to hell, we took the wheel apart, and set everything down so we could put it back in, that way it wouldn't be so much of a puzzle to put back together. but that failed and now we are having problems figuring out exavtly what parts go back in in what order on my 1981 Chevrolet Van G10
First of all, you have no rear axle. Are you talking about the subframe or your hubs? As for drum size, I would go with the same size that are coming off. If you want to (and can) go bigger, you just need to make sure they have enough clearance inside your wheels. When ordering parts, you will be asking for: wheel cylinders, shoes, spring kit and drums. Note: the wheel cylinders you will only need to change if you are changing the SIZE of your drums or IF THEY LEAK. To see if they are good, pull your drums, smack your shoes from one side then to the other (using the palms of your hands) then back to center. Pull back the rubber boots and inspect for moisture. If they're dry, don't change the cylinders. If they're wet, they're leaking and need to be replaced. Now, if you do need to replace your wheel cylinder(s), you need to look in behind and assess the condition of the brake line fitting. If it looks rotten beyond all hell, you'll likely be into doing the brake line(s) as well. NOTE: when you actually do get into changin your brakes, do ONE SIDE AT A TIME. Drum brakes can be complex and if you take apart both sides then you have no reference as to how to put them back together!
Raise and support the vehicle. For additional information, refer to Section 100-02.
Remove the wheel.
Release the brake shoe automatic adjuster.
Remove the brake drum.
Remove the retainers (if equipped).
Remove the drum.
Make sure that the hub flange is in the correct position as shown.
Remove the hold down springs.
Disconnect the parking brake cable.
Lever the secondary shoe outwards.
Disconnect the cable from the secondary shoe.
Disconnect the shoes from the anchor block.
Remove the lower return spring.
CAUTION: Do not damage the wheel cylinder boots. Detach the shoes from the wheel cylinder.
Hold the wheel cylinder pistons in place with a rubber band.
Remove the upper return spring.
Remove the primary shoe from the strut and brake shoe adjuster.
Rotate the adjuster counterclockwise.
Remove the primary shoe.
CAUTION: Take care as the strut support spring is under tension. Detach the secondary shoe from the strut support.
Detach the strut from the shoe by levering the strut against the shoe.
Remove the parking brake return spring.
Installation NOTE: Install new shoes as axle sets.
Clean, check and apply Silicon Dielectric Compound D742-18A331-A or equivalent meeting Ford specification ESA-M1C171-A to the backing plate contact points.
Install the parking brake return spring.
Install the secondary shoe to the strut and brake shoe adjuster.
Install the primary shoe to the strut and brake shoe adjuster.
Install the primary shoe.
Rotate the adjuster fully clockwise.
Install the upper return spring.
Remove the rubber band holding the wheel cylinder pistons in place.
CAUTION: Do not damage the wheel cylinder boots. Position the shoes to the wheel cylinder.
Position the shoes to the anchor block.
Install the lower return spring.
Install the hold down springs.
Install the parking brake cable.
Install the cable to the secondary shoe.
Install the brake drum.
Install the drum.
Install the retainers (if equipped).
Install the wheel.
Operate the brake pedal to achieve automatic adjustment.
Most likely rellted to the rear wheel cylinder. You need to remove the tire, probably replace the brake shoes if they are wet with fluid, wipe down brake drum with carb or brake cleaner, install new wheel cylinder and put everything else back together. Wheel cylinder is available through most auto parts outlets. Probaby less than $15.
Remove wheel, brake drum, and brake shoes. The cylinder is the part the brake line goes into and it spreads the brake shoes apart when you brake.
Loosen the brake line but do not take off, unbolt the cylinder and then disconnect brake line. loosely connect the brake line to the new cylinder so you do not loose much brake fluid, bolt new cylinder in and then tighten the brake line. Reinstall shoes. There should be a bleeding screw/grease head in the brake cylinder, loosen this and have someone step on the brake to bleed the line, have them hold the brake while you tighten the bleed screw. Do this as many times as necessary until brake fluid only with no air comes out. Reinstall drum and tire, top off brake fluid.
tack of drum look for cracks look for scaping jack up securely tern tier by hand take apart side that is making most noise. it shouldn't take any time towear in this ant right have some one else do it.
there is no springs on brake pads, if you mean rear drum ,brake shoes,which springs are you having trouble with,the round cylinder springs that hold the shoes fast to the backing plate or the the return springs that bring the shoes back after being pushed out by wheel cylinders.
If you are just replacing the shoes and drums then it's really not a bad job. Replacement parts are fairly cheap and you can get away with doing most of the job with needle nose pliers instead of buying special tools. I'd recommend you drive with your e-brake on a little just to scuff off any ridges on the drums or shoes before you take off the rear wheels. This makes the drums a lot easier to get off, though you'll still probably need a good sized hammer and a lil elbow grease.
Support the rear axle with jack stands and chock the front wheels. Take off the rear wheels. Give the drums liberal love with a good sized hammer, I've even seen sledges used on real bad ones. Once they are free take off the drums. Note the positions of all the hardware, maybe even take a digital camera pic since it's your first time, everything must be hooked up as it came off. Hold the pin on the back side of the backing plate and use the needlenose to twist it out of it's holder to get the shoes off, then clean everything with brake cleaner (get it at the parts store with the parts, 2 cans should be ok). Apply wheel bearing grease wherever the shoes will touch a flat part, should be 2 or 3 on the backing plate. DO NOT GET GREASE ON THE SHOE FRICTION MATERIAL!... brakes will smoke bad and not work so hot if you do... so a little dab will do ya, just enough to keep them from being noisy or binding later. Assemble as you took them off. Don't forget to tighten the lugs again after the truck is on the ground. Adjustments can be made with the adjuster wheel in the middle and a flat head screwdriver by popping out the rubber cap on the backing plate. Match the number of clicks or turns on both sides.
Thorough cleaning and lubing of moving parts while you have everything apart will make your brakes work well and keep life easy for you. Inspecting the wheel cylinders (on the top between the pads) while everything is apart is a good idea too. They're cheap and now is the time to replace them if you need to. Look inside the rubber boots for brake fluid and check around them for evidence of leaks, it's not worth doing if you're just gonna ruin the parts you're putting on so do it if you need to, or just for the hell of it.
Hope that helps.
check to make sure that you did not put both primary brake shoes on one side. it is common for the rear brake shoe to be a little larger than the front and sometimes a little thicker.
Item
Part Number
Description
Brake Shoe Hold-Down Spring Pin
Rear Wheel Cylinder Retaining Bolt (2 Req'd)
Washer (2 Req'd)
Anchor Pin (Part of 2211)
5
Wheel Cylinder
6
2028
Brake Shoe Anchor Pin Guide Plate
7
2A637
Parking Brake Lever
8
2296
Brake Shoe Retracting Spring (Short)
9
2296
Brake Shoe Retracting Spring (Long)
10
2200
Rear Brake Shoe and Lining (Secondary)
11
Washer
12
2106
Parking Brake Lever Pin Retainer
13
Brake Shoe Adjusting Lever Cable Guide
14
2A642
Primary Brake Shoe Parking Brake Lever Link
15
2A601
Parking Brake Link Spring
16
2068
17
2A176
18
2048
Brake Shoe Adjusting Screw Socket
19
2047
Brake Shoe Adjusting Screw Nut
20
2041
Brake Adjusting Screw
21
2049
Brake Shoe Adjusting Screw Spring
22
2200
Rear Brake Shoe and Lining (Primary)
23
2A178
24
2211
Brake Backing Plate
Heavy Duty Rear Brake
Item
Part Number
Description
Lock Nut
Rear Brake Backing Plate
Rear Wheel Cylinder
5
2A642
6
2A601
7
2A637
Parking Brake Lever
8
2106
9
Parking Brake Lever Bolt
10
Secondary Shoe Assembly
11
2A179
12
2068
13
Adjusting Lever Pin
14
Adjusting Lever Return Spring
15
2A176
16
2047
17
2049
18
2041
Brake Adjuster Screw
19
Primary Shoe Assembly
20
2068
21
2200
22
2035
23
2A178
24
2092
Brake Adjusting Hole Cover
25
2069
The rear drum brakes:
Have internal shoes that expand against the brake drum (1126).
Are a single-anchor type.
Are actuated by one rear wheel cylinder (2262).
Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
Adjust rear brake shoes and linings (2200) automatically.
Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
