Question about Nintendo Wii Console
My Wii keeps saying "unable to read game disk". It is a new game with now scratches.
Posted by davo20 on
seth adams
  • 1,531 Answers
The lens may be bad or needs to be cleaned.is the machine scratching the disk.if so there maybe some kind of foreign object or a broken piece of plastic inside the machine.
Posted on Jan 24, 2010
I have a Nintendo Wii and every time when i put in Wii sports resort it always says unable to read disk check Wii operation manual guide for help troubleshooting. but i lost my Wii operation manual guide...
Your disk may be scratched or dirty, make sure it is inserted the correct way. try inserting another wii game and see if it can read that.
You can try to clean your disk using this guide, but if its scratched then it wont help.
Jul 31, 2011 | Video Game Consoles & Games
I have no problems turning on the Wii, but when I go to click on the game, it says unable to read the disc with a big question mark.
The disk could be to scratched/damaged for the WII to read or the WII could be broken. Another possible issue is the WII has to much dust and needs to be cleaned(with compressed air).
I would recommend trying another disk and if it works you most likely have a bad disc. If not, I would contact Nintendo to have the WII repaired as it should still be under warranty.
Regards,
G33k
May 09, 2011 | Nintendo Wii Console
Every time a game is put in the Wii says 'unable
You could try a 3rd party slot cleaner, or use the tried-and-true retro Nintendo console method of blowing into it.
How scratched is the disk? If it's really beat up, that might be the problem right there.
I had a similar problem before, and neither of my methods worked. I had to get it fixed by Nintendo themselves. Hopefully you don't have the worst-case scenario!
May 07, 2011 | Nintendo Wii Console
Hi this is zakary i have a game called wipeout but when i put it in a errors come up saying turn off the wii take out the game then get more info in the manaul itryed every thing the wii said what the...
Is the disk dirty or scratched? This error commonly occurs when a damaged disk is unable to be read by the system. If your other games work, then the cause is likely the disk.
Apr 30, 2011 | Nintendo Wii Console
When i put in wii music it says unable to read disk please refer to the wii operations manual for troubleshooting what is wrong with wii music?
Check if the disk is scratched and if is a new game, make sure is the same region as your wii unless you want to softmodded to unlock region.
Jan 17, 2011 | Nintendo Wii Console
When a disk is inserted, error message says "unable to read disk".
You might either have inserted the disk the wrong way, flip it around. Or the disc is scratched/dirty The Wii might not also recognize the CD.
Hope this helps : )
Dec 31, 2010 | Nintendo Wii Console
The wii is giving the message "unable to read
  • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
  • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
  • Ensure that you are properly loading a Game Disc.
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
Dec 29, 2010 | Nintendo Wii Console
Circle scratches on wii games
(For Quick Solution Read All Caps) I Did Also... you need to remove the ga,es from the after playing... and if you stop playing the wii take the disk out... the wii keeps reading the disk no matter what you are doing so... simply put:
TAKE THE DISK OUT IF YOU ARE NOT PLAYING IT
Dec 13, 2008 | Nintendo Wii Console
New Wii Game Unable to read disc
You may have to replace the laser in the wii so that it can read the disc, if this isn't thecase, then I don't have any other solutions for you.
Jul 17, 2008 | Nintendo Wii Console
Unable to load games
I have a very similar problem that my wii console gives me black screen with disk read error every time I inserted a new disc that worked previously. The way I worked around this problem is by
1. ejecting the disc
2. powering off(hold the power button for about 10 seconds)
3. unplugging the power cord
4. waiting one minute or so
5. plugging in again and re-inserting disc
This worked every time when I switched disc.
Nov 17, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
