Frigidaire FEF376 Electric Kitchen Range Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you raise the smooth cooktop on a frigidaire range?
Anonymous
Level 3:
  • Master 1,531 Answers
  • Posted on Jan 24, 2010
Anonymous
Master
Level 3:
Answers
1531
Questions
0
Helped
406599
Points
4453
The cook top is screwed down with several different screws it does not just lift up.what is the reason you want to raise it up.
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
I have frigidaire electric range FES367DQA. I cracked the cooktop and would like to replace it. I found that there is no glass cooktop for my range but there is for FES367DBA and DCA. The difference i
Thank you for your post, isaak goldman!
I understand that you are seeking instructions in order to replace the cooktop on your Frigidaire range. However, this is not a simple DIY job. I would recommend having a professional technician come out to ensure that the range is properly disassembled and the cooktop installed correctly to prevent any future issues. Hope this information is helpful. -Matt
2answers
Broken cooktop
look just call frigidaire and tell them it just cracked it has a five year warranty the tech don't care he gets his cash his pay for fixing it not being a frigidaire police man just tell him it cracked you don't know why they have a five year warranty could have already been cracked when you got it and you didn't know now couldn't it
6helpful
How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
1helpful
SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
3helpful
2answers
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
