Question about Tylo SPORT-U2 Sauna Heater 2 kW
Heater only gets mild warm Tylo sport 4 heater
Heater only gets mild warm even after 50 minutes or more. The heating wires does not get red hot. Is that the problem of installation or the unit itself.(Tylo sport 4 heater )
Posted by dwl9 on
Anonymous
    Problem Solver:
  • 9 Answers
More than likley installation problem not enough voltage top operate heating element
Posted on Feb 01, 2010
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
1999 dodge 5,9 diesel warm heat only
First thing I would do is flush the heater core with a 4 to 1 mixture of water and muratic acid. Put it in there and blow it out both ways 3 or 4 times. Let the acid mix set for about 10 minutes before blowing it out with air. This is a cheap fix, if it works. $7 and your time. Got to say though, it only works about 30% of the time. The other 70% is to remove the heater core. Dodges/Chrysler su(k. To get to the heater core, you have to drop the steering column, and remove the entire dash. Then remove the heater/A/C plenum to remove the heater core. Buy a manual to do this. Way to many hidden screws and bolts. This job costs about $800 at a garage. It takes about 8 hours to do, if you know what your doing.
Dec 07, 2014 | 1999 Dodge Ram
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
I have an 01 Jeep Cherokee Sport. I am having
As soon as the vehicle reaches around 180/195 (depends on the temp of the t-stat) the thermostat should open and thereby filling the top hose with warm/hot water.
Are you sure the thermostat is facing the right direction? Is the cooling system full?
Here is what you can do: remove the t-stat, replace any lost coolant/water and run the vehicle with heater on full blast for about 15 minutes or until the temp gauge is showing about halfway. During this time be sure to monitor the coolant level in the reservoir.
If you still have no hot air you may have a blockage or perhaps the heater hoses are not even connected.
Jan 06, 2010 | 2001 Jeep Cherokee
Tylo SPORT-U2  Sauna Heater 2 kW Logo
416 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
