Question about Watches
I have a Pulsar watch, haven't used it for at least 10 years & can't find the manual. The model no. on the back seems to be W850-4030. Can you help?
Posted by machelli on
David Tolond
    President:
  • 2,501 Answers
It seems as though Pulsar are made by Seiko.
I couldn't find your model on their web site so you might have to do some digging to get this information you want. 10 years is no great age for a watch, so the maker should still have your manual on record.
If you go to the Pulsar web site (pulsar.com) you will be able to find a store locator where you can get advice or you could contact them (bottom of web page, right) by email.
Posted on Jan 24, 2010
I have a Pulsar watch need to change to day light saving time
just put the hour hand forward or back 1 hour
Mar 15, 2016 | Pulsar Watches
I have a pulsar watch model pq2003 but, I NEED a owners manual to know how to set all the different options...where can I get one?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all PULSAR watch manuals.Rate me, please
Mar 18, 2010 | Seiko Pulsar watch
I need a manual for a Pulsar watch calibur #7T62
Pulsar are made by Seiko and support can be obtained from their web site. (The number your quoted is a Seiko number- all Pulsar models seem to start with two or three letters).
Put "www.seiko.co.uk/support/instructionbooklets" into you search engine and you should come to the Seiko instructions list. Scroll down to find your watch and download the instructions.
Mar 06, 2010 | Seiko Pulsar watch
I have a men's pulsar watch 783020. I need to know how to turn off the alarm?
http://www.seikowatches.com/support/ib/index.html
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 22, 2010 | Watches
I Have a pulsar 783020. I need to know how to turn off the alarm.
Hope this tip helps
R/
David
Feb 22, 2010 | Seiko Pulsar watch
The timer on Pulsar watch does not line up at 12 when reset.
To set the timer hand on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#1), FIRST CLICK (#2) & SECOND CLICK (#3).
First, pull the crown out to the second 'click' position (#3) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #3!)
Push and hold Button "A" for two (2) seconds. The dial will sweep around to the 12 O'clock position. You can advance the timer while the crown is in position #3 (second click out) to reset it back to the default position.
The manual says that if you pull the crown out to position #3 while the timer is measuring, the hand will reset back to the 12 o'clock position... I haven't tried that, so I can't confirm.
Jan 02, 2010 | Pulsar Chronograph Watch
How to set alarm for pulsar chronograph model ym62
Operating manual for Pulsar, YM62. ALARM & CHRONOGRAPH.
http://www.pulsarwatches.com.au/files/instructions/137_1.pdf
This is an exact copy of my user's manual (instructions) that came with the mod. YM62.
Aug 12, 2008 | Pulsar Watches
Pulsar watch band
I have a Pulsar watch and on the expandable band, the casing fell off and can't get it replaced unless we take off a link...To me this was too much trouble, time and expense...I won't buy another Pulsar! Too bad cause I thought it was a beautiful watch.
Jun 15, 2008 | Pulsar Watches
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Watches Logo
192 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
