Question about Kodak i1220 Pass-Through Scanner
Problems with Kodak i1220 Smart Touch software
Problems with Kodak Smart Touch software that came with Kodak i1220 scanner. Every time I price button I receive the message: Failed to start scanner. Please make sure the scanner is connected and powered on successfully. If necessary, exit Smart Touch from the system tray and restart it."
Posted by martyzm on
Mikejdot
  • 3 Answers
Go into C:\programdata\ and remove the kds_kodak folder. It may ask you to skip files it can't delete. Just click skip for all of them (probably around 15 files). Then reboot your computer and you should be able to scan.
Posted on May 16, 2013
4 Related Answers
Anonymous
  • 7 Answers
SOURCE: i1220 scanner jamming
test the scanner using the scan validation tool to see what errors there may be. also make sure that the length detection settings in the driver is correct as this may also cause a problem, contact the support centre if the issue is not resolved, they can do a replacement for you
Posted on Dec 11, 2009
Anonymous
  • 7 Answers
SOURCE: red and green lines through prints from a kodak
clean the scanner with anti static wipes and vacuum clean the scanner, if this does not work then call the kodak techs again and they can send a cleaning kit or a replacement scanner. the lines are caused by dust in the scanner
Anonymous
  • 7 Answers
SOURCE: kodak I1220 is connected but can not be started by
update the driver and the smart touch driver from the kodak website. make sure that the scanner is not connected when you do this. if this does not resolve the problem, then contact the kodak scanner support call centre as this could be a problem deeper within the pc
Anonymous
SOURCE: kodak I1220
Kodak i1210 the red led is flashing and no work
Posted on Mar 26, 2010
Need i1220 license
There is not a "license" to use a i1220 scanner. If you are referring to a license needed for Kodak Capture Pro software, then contact 1-800-822-1414 for assistance with acquiring a license.
Apr 08, 2014 | Kodak i1220 Flatbed Scanner
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
I just received my i1220. After it powered up the light that comes on is constant red. The light does not go green.
What software are you using?
Have you installed the TWAIN driver for your operating system?
Jan 08, 2011 | Kodak i1220 Pass-Through Scanner
Kodak I1220 is connected but can not be started by button nor smart touch
Nov 09, 2009 | Kodak i1220 Pass-Through Scanner
Red and green lines through prints from a kodak
Aug 06, 2009 | Kodak i1220 Pass-Through Scanner
Kodak I1220
Jun 24, 2009 | Kodak i1220 Pass-Through Scanner
Kodak i1220 Pass-Through Scanner Logo
3,597 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
