If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO
NOT power the scanner OFF until the INITIALIZE process is complete
(M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure
will reset the scanner to original factory settings and erase all data
that you have programmed.
BillB
