Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
We have a jetted tub and I would like to remove the jets and just put in a plug of some sort - making it a regular tub - any ideas
Posted by heywhynot on
US Parts Center
  • Whirlpool Master
  • 719 Answers
No such items exist. use it like a jetted bathtub or pull it out and put in a soaker tub.
Posted on Sep 06, 2010
notusingspa
  • 0 Answers
Would someone please create this item! I wish I could remove my jets and put a flat-type plug as well.
Posted on Sep 30, 2014
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 | Jet Home
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
Get jets unplugged
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Jan 19, 2014 | Whirlpool Home
My Royal bath tub leaves residue each time I use it. How can I stop this
US Parts Center
Oct 18, 2013 | Whirlpool 5"x36" White Bathroom Drop-in ...
I need to know how to clean the jets in our eljer spa tub
Cleaning your Tub
US Parts Center
Oct 04, 2013 | Eljer Home
Can I simply silicone jets in a tub to seal them completely, so the jets don't leak? It's for a rental unit I own, bathroom on 2nd floor. Don't want to tear out the bath tub or ceiling on Main floor.
In order to properly seal the jet in place with silicone you must remove the wall fitting from the inside of the tub. The wall fitting is threaded into the jet body from the inside of the tub.
Once the wall fitting has been removed you can put a small bead of silicone around the underside of the flange and thread it back into the jet body. Clean up the excess silicone after it squishes out with DeNatured Alcohol.
If you plan on just putting a bead of silicone around the outside edge of the jet body behind the tub, do not waste the silicone or your time as it will not solve the leak in the tub.
US Parts Center
Sep 12, 2013 | Jacuzzi - Bathtub - Alcove - Navona -...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
1,233 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
