1999 GMC Suburban Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 chevrolet suburban: door panel removal
1999 chevrolet suburban: how do you remove the door panel. i need to replace lock actuator, i think.
Anonymous
Level 3:
  • Master 335 Answers
  • Posted on Jun 19, 2010
Anonymous
Master
Level 3:
Answers
335
Questions
0
Helped
274827
Points
1135
Hello here is the instructions for removing the door panel.
  • Remove the door handle bezel.
  • Remove the window handle,.
  • Remove the power accessory switch panel.
  • Remove the trim panel upper extension
  • Remove the trim panel screws.
  • Remove the courtesy light,
  • Remove door panel screws.
  • Remove the trim panel from the door, carefully sliding the trim panel up to release the retainers from the door.
  • Remove the speaker wire.
  • 1999 chevrolet suburban:  door panel removal - 3470484.gif
    1helpful
    Why doesn't passenger door unlock with key fob or switch?
    Dannie, power lock actuator faulty. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Front Door Lock Actuator Replacement 2007 to 2012 Tahoe Silverado...
    How to remove door panel 2008 Chevrolet Silverado 1500 LT better quality
    Automatic Power door lock repair 2007 2014 GM Truck Suburban
    The rear passenger door locks do not work on our 1999 GMC Suburban. I've checked the fuses and they all work; I tried to physically pull the lock button but it will not move: and I attempted to open the...
    If the lock button doesnt move look like you door lock actuator jam you have to find a way to move the rear panel by the inside and unlock it manualy
    Replace door actuator
    1999 Ford Explorer Door Lock Actuator
    REMOVAL:
    1.Remove the front door trim panel.
    2.Remove the water shield.
    3.Remove the power door lock actuator.
    4.Disconnect the electrical connector.
    5.Drill out the rivet.
    6.Disconnect the actuator rod.
    7.Remove the actuator.
    Attached images 4834d1192136560-door-panel-diagram-ford-explorer-80937917.gif
    Open a suburban door when both handles are broke
    ok easy to fix. remove door panel. when u have the replacement parts. start with the outside handle, remove the bolts, undo the bar, remove the handle. same with the inside handles
    My 2006 Yukon liftgate does not lock with the other doors. Can someone help me? Thanks!!
    It is probably the actuator inside the tailgate. I found this URL on internet http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/ Although not your problem, it will assist you in panel removal and actuator repair or replacement.
    How do I replace the door lock actuator on a 1999 Mercury Villager w/o damaging the connecting rods and door track?
    SECTION 501-14A: Handles, Locks, Latches and Mechanisms 1999 Villager Workshop Manual REMOVAL AND INSTALLATION Actuator —Power Door Lock, Front Removal
    1. Remove the front door latch. For additional information, refer to Latch—Front Door .
    1. Remove the power door lock actuator from the front door latch.
      1. Release the locking tabs.
    go here too
    http://groups.yahoo.com/group/villagerquest/
    How do I replace the exterior lock on a 2001 suburban that was broken into by having the lock popped?
    Which door? Doesn't really matter, you have to go in from the inside to remove the keeper and disconnect the linkage to the electric actuator. Lots of little things in the way in there so watch yourself. Was the door damaged? Should just be able to remove the screws around the handle and pop the plastic retainers loose from the lower part of the door panel, be gental, they do break. Once the panel is loose it should lift up out of the window channel. You will have to disconnect the wireing and anything else that is in the way.
    1999 GMC suburban locks seize in locked postion
    I just bought a 1999 Suburban and all of the door lock actuators were bad including the rear (barn style door) while I was replacing the rear door acuator I noticed that even with the factory mounting bracket on the actuator it was causing the door lock rod (the rod from the keyed cylinder lock to the actuator) was on a bind......the solution I came up with is adding an additional 3/4" spacer between the factory mount bracket and the door attach point. this solved any binding and the door lock works great now........also I used a lubricant on all the doors where the rods run through the plastic guides, which seemed to help quite a bit! Hope this help's.
    1helpful
    2answers
    99 CHEVY VENTURE HOW TO GET AT AND REPLACE DRIVER SIDE ACTUATOR TO OPEN AND CLOSE DOORS.
    Here's a great video that will show you how to replace your door lock actuator.">
    Poping the hood with a don't inside latch of the hood
    I have a 1999 Suburban that has several of the door latches that do not operate properly with the remote button or the power door lock button on the door. If your locks open okay with the key, it is most likely the lock actuator that is the problem. The coils on these can get weak and not be able to operate the locking mechanism. Changing them out is probably required. Haven't actually changed mine yet, but have taken door panel off to lubricate actuator rod. This helped only briefly. Good luck. The actuators themselves are quite expensive from the dealer. ($60-$80 each, excluding installation)
    If you mean the door handle on the inside of the vehicle, it is probably broken. So, when you pull on it it can't pull the actuator rod. You have to change the handle assembly. They cost about $40. But you have to drill out the rivet. So buy a pop rivet gun and a trim removal tool. 1. Un-bolt the window regulator panel (after you have removed the trim panel) 2. Pull the top the panel back a bit. Lowering the window about 3 inches will help. But, don't pull on the panel too hard. 3. Stick rim removal tool in there and pop off the power door look rod. 4. Use you hand and pop off the handle actuation rod 5. Drill out the rivet on the latch assembly 6. Slide assembly forward and remove. 7. Do things in reverse to reassemble
    Top GMC Experts
    ZJ Limited
    ZJ Limited
    john h
    Thomas Perkins
    Thomas Perkins
    Are you a GMC Expert? Answer questions, earn points and help others
